help what motor?
help what motor?
I am trying to find what motor is in my car I found the numbers stamped on the front of the block and they are v0108dbk I went to several sites to decode but can not find the dbk part anywhere does any body know what this is?
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: help what motor?
im pretty sure you need the numbers stamped on the back of the block on the "flange?" that runs accross the rear of the block that bolts to the tranny. i hope this makes sense, im not very good at describing stuff.
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
As you probably found already the V = Flint engine plant,the 0108 would be January 08 and I found DBK listed for '92 as a 170HP 305 TBI for manual trans.That's not to say that the code hasn't been used before.As 89importeater suggested the block casting number would better ID it.Check this site
http://www.mortec.com/location.htm when you find it.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You should have a 10 bolt, but as frequently as rear-ends are swapped it's not surprising.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I thought the 9 bolt appeared in 1985...
If you have the SPID sheet look there and you will find the ratio G?? usually is the axel stuff.
In 1985 the V8's there were 3 to choose from:
LB9: TPI 305 - A4 - VIN F
L69: HO 305 - M5 - Vin G
LG4: Base V8 M5 or A4 trans. VIN H
Does your car have a 92 Engine, but the car is a 85???
If it was replaced it would not surprise me if someone did not put an el cheepo crate motor, as they are still only $1800.
John
John
Engine: 383 Carb
Transmission: 4L60
