View Poll Results: Where is your center console SPID label located?
On the bottom side of the lid.
25.93%
Inside the box, on one of the sides.
20
74.07%
Voters: 27. You may not vote on this poll
Center console SPID location
Car: 87 IROC-Z, 82 Pace Car
I constantly hear people state on here that the SPID label is located under the lid in the center console for certain model years. I can't recall hearing anyone state that the label is in the lower portion of the console on the side. I know that my car can't be the only one with the label on the inside side console. Check your car and if it's in the center glove box, where is your label?
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Center console SPID location
Scott the location on the console itself makes much more sense than on the lid.To install n impotant service decal on a part that can be easily removed or damaged due to wear wasn't a bright idea.
But then my '73 CST's version of the SPID is on the driver's side inner fender.
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
My '84 T/A and the console lid I have from an export-Canadian '84 T/A have the SPID label on the underside of the lid.
A friends '87 IROC has it on the underside of the lid and '88 IROC and '89 RS have the SPID labels on the inside wall of the console glove box.
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
The label is nowhere on my 1992 Firebird
IIRC it was on the lid on my '85 S/E, but I think it was about to fall off...or maybe already had...
On my '84, it was definitely on the bottom of the console lid.
-Paul
IIRC it was on the lid on my '85 S/E, but I think it was about to fall off...or maybe already had...On my '84, it was definitely on the bottom of the console lid.
-Paul
My 90 Formula had it on the side of the console comaprtment
My 88 Camaro had it on the side of the console comparment
My 84 Firebird had it on the bottom inside of the Lid
An 87 Camaro Iroc-Z I swapped a 4th Gen console inot, had it on the bottom inside of the lid.
My 87 Firebird (my 83 T/A didn't have one, but no 82 or 83 3rdgens did) didn't have one.
My friends 91 Camaro RS is in the rear compartment on the inside of the door
Car: 91 Z28
Engine: LB9
Transmission: auto
My 89 RS has it on the inside of the box on the passenger side of the compartment, but I bought a lid off of ebay and it had the SPID on the bottom of the lid. Now my RS has two SPID's
Ok then, it sounds like 87s have a discrepancy. Those with an 87 that have it on the lid, are these by chance Norwood cars. Since people are saying the earlier cars have it on the lid and the later cars are inside, that could mean that Van Nuys was inside and Norwood was on the lid. Any feedback on this one? This could help people restoring their cars place things in the proper location based on build location. If that's the variable.
Car: 1987 IROC (parts car) '86 IROC
Engine: 5.7, None
Transmission: 700R4, None
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
My Van Nuys 87 has it on the side, same goes for my 89.
Axle/Gears: 9-bolt/3.45
