1987 iroc no options
Old Nov 3, 2007 | 12:06 AM
1987craig-iroc's Avatar
i recently purchased a 1987 camaro iroc and it has no options. no air,tilt,cruise,powerwindows, locks, or mirrors, it even doesn't have a button to open the power trunk. The fuel tank seems small, the speedo goes to 145mph, has 4-wheel disc brakes and the 350 auto. no t-roofs either.
does anyone know more about this car?
Craig
Old Nov 3, 2007 | 12:24 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: 1987 iroc no options
Still have the SPI sheet (check center console)? Post it if you do.
Old Nov 3, 2007 | 12:45 AM
spi sheet optionless 1987 iroc
this is the spi sheet in my optionless 1987 iroc
it will not let me post
i can email it
Last edited by 1987craig-iroc; Nov 3, 2007 at 01:16 AM. Reason: Automerged Doublepost
Old Nov 3, 2007 | 01:25 AM
here it is, sorry
Old Nov 3, 2007 | 04:05 AM
Zwrench's Avatar
Car: 1987 IROC (parts car) '86 IROC
Engine: 5.7, None
Transmission: 700R4, None
That's a lean IROC alright. I could live without those other options but no tilt? I wonder how long it sat on the lot before it sold?
Old Nov 3, 2007 | 05:38 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
That must be the lightest L98 IROC-Z ever LOL!
Old Nov 3, 2007 | 10:53 AM
I also own a 1991 z28 with full load/no t-top. the rear brake rotors on the 87 are thicker by almost 150%. The L98 is in the 91 @ 245hp. The 1987 would hammer my 1991, hands down, the 91 has 56250 original miles. The 87 has 93125 miles. Go figure
Old Nov 3, 2007 | 11:40 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Almost looks like a 1LE prototype SPID IMHO.
Old Nov 3, 2007 | 01:27 PM
my front sway bar diameter is 1.375"
engine code on block is VO5155NA followed by 1HL139296
Old Nov 4, 2007 | 12:36 AM
coolram62's Avatar
Engine: LU5 305 CFI
Well you have a matching numbers motor with the HL139296
V -build plant- Flint
05 -build month- May
15 -build day
The 5NA is the engine code but the 5 must be a S.SNA denotes a 350 for '87
H -build year- 1987
L -vehicle assembly plant- Van Nuys
Old Nov 4, 2007 | 01:34 AM
89Formula3's Avatar
Car: 91 Firebird
Transmission: 5 speed
Who ever purchased that car when new had only one thing in mind SPEED.
Old Nov 4, 2007 | 09:26 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Z49 ... Canadian car too. Gotta go fast up here to keep your engine warm when it's cold out. :-)
I recall test driving an 88 Iroc back in 88. Guy ordered it, and decided not to buy it. It had a 350, Auto and that's about it. No cassette deck - just AM/FM. Figured the person who ordered it just wanted a go fast car.
Mark.
Old Nov 4, 2007 | 10:50 PM
capn smokey's Avatar
I have an 87 also that came with no options, my car has no a/c, radio, heat insulation or any sort of accessories. It also has extremely stiff suspension and thicker sway bars, I always thought it was a 1le but they didnt make those in 87. Go figure...
Out-Cast
Dec 31, 2015 04:40 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Out-Cast
Aug 17, 2015 10:57 AM
