1989 formula WS.6 ???? HELP
Old Feb 20, 2008 | 11:06 PM
fbodyguy27's Avatar
so im looking at a 89 formy and it has the performance suspension on the dash amd like does that mean its a ws.6 ? how can i tell anything helps
Old Feb 20, 2008 | 11:12 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Re: 1989 formula WS.6 ???? HELP
it should have a rpo code ws6 on the sheet in the console. Mine have the performance suspension badge and there is the ws6 code.
Old Feb 20, 2008 | 11:20 PM
fbodyguy27's Avatar
ok ill check it out thanks
Old Feb 20, 2008 | 11:30 PM
JT's Avatar
JT
Community Administrator
According to our moderator okfoz, who is very knowledgeable on the Formulas in particular, he has stated all 87-92 Formulas received the WS6 suspension.
However, note that the "Performance Suspension" badge does not automatically mean that the vehicle has the WS6 suspension. For instance, as stated above, there were Trans AM that came with the "Performance Suspension" badge, but were not equipped with the WS6 suspension.
Of course if you want solid evidence that your vehicle has the WS6 suspension, check the RPO sticker for the RPO WS6, as noted above.
Old Feb 21, 2008 | 07:55 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If its a Formula then yes it will have WS6 & a V8 of your choice. To make sure its a Formula look at the SPID sheet & VIN,
The VIN should be 1G2FS21??K
John
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
FormulasOnly
Jul 23, 2018 08:47 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
okfoz
Oct 13, 2015 02:19 PM
wanext
Oct 6, 2015 12:18 AM
