Anyone know what color the GFX is on 84'?
Old 03-17-2008, 10:15 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
Well I have the off white model with the silver GFX and i was going to just repaint the whole GFX and wanted to pick up the closest color spray paint I could find. Any suggestions I know perhaps there is a color code but my glove box lid is off a diffrent car so no code there. but perhaps I need more of a color of spray paint i should use.
Old 03-18-2008, 12:56 PM
AmorgetRS's Avatar
Re: Anyone know what color the GFX is on 84'?
Moved to History/Restoration, you'll have better luck there.
Old 03-18-2008, 04:37 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
When you state the color of your '84 is off white could it be beige?If you look on the top center of the radiator support you'll find a trim tag.On the second line the first code(2 numbers and a letter)is the interior color code/type,the second and third series of codes are for exterior color.For '84 I only see code 11 white and code 59 beige(only available in '83 and '84).And I've never seen a beige car with silver GFX.I'm not saying there weren't made just the only ones,including mine,have gold GFX and wheels.Also the trim tag doesn't show GFX color on the trim tag(at least in '82 & '83).
I hope this is of some help or someone with a '84 Z the same color code as yours has thier build sheet or SPID
Old 03-18-2008, 08:45 PM
David M's Avatar
Car: '84 Z28
Engine: L69
I've got a white '84 with the silver gfx and the silver paint code is not on the SPID label nor on the build sheet. But when I repainted the car I did some research and found a silver accent color for 1984 Chevrolet Camaro deep in a paint book at a dealership where I had the car painted. The code is #7448 DuPont. We shot the gfx that color and it's dead nuts on!! I don't know if this is available in a spray can though.
Old 03-19-2008, 06:55 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Here is what my research produced for Silver Ground effects:
Color Code 16
wa7448
PPG 3308
Dupli-color GM301
Linson
09-25-2021 07:55 PM
Jorlain
Exterior Parts Wanted
06-29-2017 11:04 PM
PAFORM350
Wheels and Tires
10-02-2015 07:21 PM
Linson
10-01-2015 09:50 PM
Dragonsys
09-25-2015 03:51 PM
Quick Reply: Anyone know what color the GFX is on 84'?
