Decoding GTA production number
Old Mar 26, 2008 | 10:19 PM
Jcous76's Avatar
Hi all, I am a new member here at Third Gen but have had quite a few of these cars in previous years. I have recently decided to pick up another car that was to good a deal to pass up. I bought a 1991 Trans Am GTA and it is the only one around I have seen this color other than the Formula's of the year so I am trying to figure out how many were this color with these options. It is a dark metallic green hardtop with a tan cloth interior fully loaded minus the deluxe overhead console. It is a 5.7 TPI with the dual cat setup, aluminum driveshaft and rear disc (9 bolt if I remember). The car is all original and still cleans up quite well. The engine is tired and has the usual worn valve stem seals so it smokes on startup and has now developed an intake manifold leak. I have bought two engines, one being a stock 1990 350 4 bolt out of a GMC truck and bought a Scat crank for a 383 setup as well as a cam but havent decided if I am going to go high compression or lower. After I had purchased this I had gotten a great deal on a LS-1 out of a 1998 Corvette but am hesitant to go the LS-1 route since the car is very clean and I do not want to tamper with the engine cradle, subframe or original wiring harness but if it is a usual run of the mill GTA and theres a lot of these cars with this combo around I will go the LS-1 route if not I will just go the mild 383. I am not looking to make a track car out of this car by any means I just want a little more power while retaining an all stock appearance. So if anyone can help with production numbers on this combo please drop a line it would be greatly appreciated!
Old Mar 27, 2008 | 08:40 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Decoding GTA production number
from the gtasourcepage.com (thanks frankie rider2)
for the 1991 GTA only:
2035 GTA's
508 Green GTA's in 1991
808 Beechwood Interiors
1,321 L98 (5.7 Engines)
1,853 JG1 -- Shaft, Propeller (Aluminum)
The Overhead console was dropped after 1988
The 9 Bolt axel was dropped in 1990
The Dual cats would have been standard with the 5.7L
Does it have T-tops?
Old Mar 28, 2008 | 01:55 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Actually, according to my stuff here.... the nifty overhead console was scrapped after '87.
Old Mar 28, 2008 | 02:44 AM
AmorgetRS's Avatar
When did 91 GTA 350s have a t-top option? I thought it was only the Formys that got that.
I own one of the other 1991 GTAs that was Green w/ a Beachwood interior, but it is a 305 AT w/ t-tops. Not that it tells you anything except that it isn't one of 508 at most it is one of 507
Old Mar 28, 2008 | 07:50 AM
okfoz's Avatar
I wasn't exactly sure, I thought it was 1988 with the exit of the digital dash. Good to know.
John
I only asked just in case he had some strange combo... He said "fully loaded" So I thought I had to ask.
John
Old Mar 28, 2008 | 11:55 AM
AmorgetRS's Avatar
John
Okay, just had to ask in case you knew something
Old Mar 29, 2008 | 12:40 AM
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Officially they did not. I have seen two 1991 GTAs in my life that had the two options and the corresponding RPO codes on the same car.
Old Mar 30, 2008 | 04:04 PM
RPM WOT L 98's Avatar
Med Grn Metallic '91 GTA here. L 98. Beechwood.
This was actually the most popular exterior GTA color for 1991 if I recall correctly.
Old Mar 30, 2008 | 04:18 PM
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Indeed.... Medium Green Metallic edged out Black by 62 units.
Old Mar 31, 2008 | 01:47 AM
AmorgetRS's Avatar
Canadian cars?
Old Mar 31, 2008 | 08:24 AM
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Honestly, I don't recall. I wasn't looking at that part of it and so I did not check for the "Canadian" codes. I didn't even know of the Canadian availability back then.
Jorlain
Oct 8, 2015 01:57 AM
carattini
Sep 10, 2015 07:46 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
greenyone
Sep 2, 2015 03:39 PM
