Difference between IROC-Z, RS ,& Z-28 camaros?
Old Apr 9, 2008 | 05:57 PM
salvamex89's Avatar
Car: 1990 pontiac Firebird
Engine: v6
Ive broken it down to these 3 cars in my area, a IROC-Z, Z-28, and RS Camaros.....The years are 1989, and 1990 and 1991....but basically what i really need to know is the difference and which one is better basically there differences from each other...It would help a lot thanks!
Old Apr 10, 2008 | 12:04 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Re: Difference between IROC-Z, RS ,& Z-28 camaros?
https://www.thirdgen.org/tech-data
Old Apr 10, 2008 | 12:29 AM
salvamex89's Avatar
Engine: v6
no man like the differnce between z28, rs, and iroc-z? not the years
Old Apr 10, 2008 | 02:11 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Here, I did a search for you and found this:
https://www.thirdgen.org/forums/hist...ween-rs-z.html
Which one is the best would depend on which engine and trans is in them and how many miles are on them. In my mind I wouldnt even touch the RS. The IROC and the Z28 are very close in performance. The IROC will have slightly better suspension but the engine packages will be the same.
Old Apr 10, 2008 | 02:57 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Honestly they used the same engine, cam specs, heads, exhaust manifolds were all the same. The difference is with the EPROM Program. The 1992 was the most economical, but otherwise there is little or no difference insofar as the engine.
The 1990 was the lowest production as they only made them thru 12-31-98.
Old Apr 10, 2008 | 10:13 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
As Kevin91Z mentioned, check out the tech data. It's not just about years. Here is an example of the data. This parts describes why the Iroc-Z was the top model to be had . . .
The new IROC-Z option was available on the Z28 and came with new 16x8 aluminum rims, P245/50VR-16 Z Rated Goodyear Gatorback tires, fog lights, CAMARO on front license plate panel, .5 inch lowered ride height, body colored valances, Delco-Bilstein rear gas shocks, special front struts, increased spring rates, special jounce bumpers, 5 degrees of caster (up from 3.5 on Z28) in front wheel alignment, `WonderBar' front frame rail stiffener, special valving in steering for increased steering effort, larger rear stabilizer bar with stiffer bushings, IROC-Z exterior decals and interior dash badge, and a thinner two-color lower body stripe.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Frozer!!!
Jan 19, 2024 04:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Fronzizzle
Aug 9, 2015 01:15 PM
