Need some documentation help
Old Jul 21, 2008 | 04:48 PM
86camarodriver's Avatar
So far I can NOT find the RPO sticker on my car (83 Z). Just e-mailed vehicleinvoice@gmmediaarchive.com on help with pulling up documentation but am hearing that GM might not be letting them help any longer.
Have heard the dealers can sometimes help but its hit an miss.
There used to be and still may be a site that for a fee will print you up another window sticker but I guess it can be hit and miss on acuracy???
Car has 26k miles and from what I can tell has everything but tinted windows and all came from the factory. I hope to find out if the tint was just removed maybe.
Any help would be great.
Old Jul 21, 2008 | 09:24 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: Need some documentation help
83`s dont have an rpo sticker.Only thing you will have is a metal plate under the hood on top of the radiator/fan shroud
Old Jul 22, 2008 | 01:12 PM
OHHH ok, I know it has one of those, don't remember and RPO codes but I was not looking for them. Ill go check.
Were those supposed to be black?
The bumper was replaced year back due to a flat bed tow truck driver screwing it up and the new one was painted and a buddy of mine things the painted painted that also (now red).
Old Jul 23, 2008 | 11:51 AM
This is what I got off the plate,
D 04D 1FP87 N157239
17G 75L 75U E
AR9 CC1
Z28 D80 PT
100741 327813
I looked in my camaro history books that has the PRO codes in the back and could find none of these, any help would be great.
Old Jul 23, 2008 | 01:33 PM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Transmission: Automatic
Marc,
I didn't know 83's came with vin plates & no stickers. When year did the stickers start?
Old Jul 23, 2008 | 02:48 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
D 04D 1FP87 N157239
17G 75L 75U E
AR9 CC1
Z28 D80 PT
100741 327813
very little of that is actually RPOs. Here is decoding for what I know off the top of my head:
N157239 - I don't know what the N is, but I believe the rest is your car's sequence number. Those 6 digits are the last 6 characters in your VIN. All camaros started with a 1 (and firebirds with a 2). This means your car was sequence #57239 for 1983 production. If that isn't the sequence number, then it's one of the other 6 digit groupings on that tag.
04D is when your car was assembled. 04 for April and D for 4th week of the month
75L and 75U are your paint code. The "L" and "U" stand for lower and upper body.
AR9, CC1, Z28 and D80 are RPOs. CC1 is t-tops, Z28 is obvious, and I don't remember the other two off the top of my head.
Old Jul 23, 2008 | 03:11 PM
Dmans85's Avatar
Car: '85 Z28
Axle/Gears: 3.23 posi
Remembered the D80 off the top of my head. Ar9 was on the tip of tongue but had to look up
Any way.. d80 -spoiler
ar9- basically trim/convenience pkg
whoops...bucket seats Ar9..
Old Jul 23, 2008 | 03:25 PM
my82roc's Avatar
Originally Posted by flippermtc
Marc,
Mike,Im not certain but Id say 1985 if I had to guess
Old Jul 23, 2008 | 03:34 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
There was an original SPID sheet in my 84 Trans Am on the underside of the center console lid that listed all RPOs
Old Jul 23, 2008 | 05:14 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The first year was 1984.
Old Jul 23, 2008 | 10:30 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
I think your mixing up your info. GM won't let Pontiac Historic Services do invoices on 87 and newer Pontiacs.
The email you listed is for Allied Vaugn. I see no reason why they can't do it for you.
Old Jul 24, 2008 | 07:30 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
D 04D 1FP87 N157239
17G 75L 75U E
AR9 CC1
Z28 D80 PT
100741 327813
From what I know about Firebirds....
I believe the first "D" is for the model year: 1983
The "1FP87" is the car series.
The "N" is plant of construction: Norwood, OH
The "AR9" is the seat code.
Everything else was explained above, I think. Good luck in your quest.
Old Jul 24, 2008 | 12:54 PM
Have yet to hear back from them.
I was told the car came with full power (t-tops obviously) and the rear wiper from the factory. Also has the dual fans but who knows if thats factory.
So it looks like the rear wiper is not from the factory? It has the washer sprayer also.
