1988 gta with Lb9
Old Jul 23, 2008 | 09:25 PM
silver69judge's Avatar
1988 gta with Lb9
Hello I just bought a 88 GTA with the LB9 305 HO 700r4 with the digital dash. How many LB9 were made> I just don't see why you would want the LB9 unless you wanted the 5 speed. Thanks. Bryan
Old Jul 23, 2008 | 09:27 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: 1988 gta with Lb9
You can find more info over at the GTA Source page
http://www.gtasourcepge.com/
Old Jul 24, 2008 | 11:29 AM
Dmans85's Avatar
Car: '85 Z28
Axle/Gears: 3.23 posi
Extra cost of $700-800 I believe swayed alot of minds I'm sure. That's 1986 dollars too.For street driving ~30 hp and some extra torque...hmm, I might of been cheap too
Old Jul 24, 2008 | 12:26 PM
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
But didn't the GTAs come with the 350 as a Standard option and then some people would choose the 305 instead so that they could receive that $700-800 in options credit? Thats what I thought but I could be wrong...
Old Jul 24, 2008 | 04:04 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Hi a mack6
You are correct. From the GTA SourcePage, there was a credit for going to the LB9 vs L98 as well as from the automatic to standard transmission. Total came to about $700 - 800 in credit dollars.
What I find interesting is that the LB9/auto combo has less rated hp that the LB9/standard. I believe the LB9 with the standard transmission got the L98 cam but I'm not sure about the LB9/auto.
Old Jul 24, 2008 | 05:09 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My friend had an 88 GTA LB9 5 speed. It was a nice car but in the span of 2 years, it went from a nice driver to a stripped chassis.
I ended up getting the T5, wheels, hood, and badges.
Old Jul 24, 2008 | 10:12 PM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
I'll save you some time. Here's the total breakdown for US cars that year....
'88 GTA with 5.7L/AOD - 6,913
'88 GTA with 5.0L/AOD - 2,043
'88 GTA with 5.0L/M5 - 809
The LB9 engine, regardless of transmission, was the only way to get T-tops in a GTA that year.... I'd wager that was the reason for so many being produced.
Old Jul 25, 2008 | 02:33 AM
Zepher's Avatar
wow, the LB9/T5 was pretty rare. A shame he let it go to ****.
Old Jul 25, 2008 | 02:44 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Just for FYI. There is no such thing as an LB9 HO engine. When Chev/Pont built a 3rd gen HO engine, they are referring to the 4 barrel carburated L69 305 engine (used in the Pontiac's from '83 - '86).
Often you'll see this related decal . . .
Regarding the LB9 cams. They did use two different grind profiles, with the slightly more aggresive profile typically accompanied by the 5 spd tranny.
http://www.gmtips.com/3rd-degree/dox/tips/cams/cams.htm
TX-SleeperC5
Feb 24, 2016 01:34 PM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
okfoz
Sep 15, 2015 05:22 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
