1987 IROC makes it into the Castrol Hall of Fame LOL
Old Aug 8, 2008 | 10:34 PM
Debritton's Avatar
Car: 1987 IROC
Engine: LB9
Transmission: 700-R4
http://www.castrol.com/castrol/gener...tentId=7046408
Old Aug 8, 2008 | 10:45 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Re: 1987 IROC makes it into the Castrol Hall of Fame LOL
That's alot of miles!
I hope my engine see's those numbers
Old Aug 8, 2008 | 11:16 PM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
mine made it about half and is dying rapidly :-/ lol
Old Aug 8, 2008 | 11:46 PM
Debritton's Avatar
Car: 1987 IROC
Engine: LB9
Car runs great... I do need to invest some $$$ into the front end suspension... my ball joints and tie rods are showing play. I get a little vibration when I slightly turn at speed.... either then that the car runs tight. The only thing I have done to the front end was replace front struts... that's it.
Old Aug 9, 2008 | 04:26 PM
Guy In A 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
Hope mine lasts that long. . .
Old Aug 9, 2008 | 04:30 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Haha, mine lasted to 69,000 miles, then bend a rod . A cop owned it... makes me wonder what he did to it. I bought it with 63,000 miles. Now it is almost at 82,000
Old Aug 9, 2008 | 08:31 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
big headline: it has seen NOTHING BUT CASTROL all its life
except clearly in the article when he says he had to use valvoline one time
Old Aug 9, 2008 | 08:58 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Congradulations David, that is an accomplishment, Though I'd say you're about 120,000 miles overdue for those front end parts.
Old Aug 9, 2008 | 11:57 PM
Debritton's Avatar
Car: 1987 IROC
Engine: LB9
Your funny. I am also not a "Liver" eater.. yet I have had the gross stuff one time when I was 6.
LOL
Old Aug 10, 2008 | 12:04 AM
Debritton's Avatar
Car: 1987 IROC
Engine: LB9
Actually Kevin.. I am surprised that the car's front end has lasted as long as it has.... Since the car is a daily driver and isn't running on the slolum coarse... in a practical sense IMO the only time you really would need a front end rebuild is if the car's handling was affected, or eccessive tire wear was evident...in this case only the first applies as it feels a little loose up front. Surprisingly my front tires have even wear-- inside and outside.
My 87 must have been assembled on a non- Friday or when GM employees were not hung over from the weekend before. LOL
Caspar
Jun 19, 2016 11:19 PM
beachrodder
Aug 25, 2015 08:05 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
jahblah
Aug 12, 2015 05:54 PM
mustangman65_79
Aug 11, 2015 03:17 PM
