RPO Code Help
Old Aug 22, 2008 | 10:52 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
RPO Code Help
I found 2 camaros in a junkyard near me and I'm trying to look up the RPO codes from them to see if there is anything special about them, or any parts I can use to upgrade mine. I have most of the codes figured out but there are a few that don't make sense or aren't on my list at all. The ones that I can't find are:
82M
AR9
QHY
These are from a Berlinetta
and:
AR9
D6H
QYH
729
I9Q
These are from what looks like a plain sport coupe.
Also, there is a thirdgen Firebird there, the interior is pretty well stripped though. Can anyone tell me where the RPO list is on them? I mainly want to see what rear end ratio it has in it.
Any help would be greatly appreciated.
Old Aug 22, 2008 | 01:27 PM
saliger64504's Avatar
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
Re: RPO Code Help
729 IS SEATBELT COLOR, DK CARMINE (9)(91)
QYH IS TIRE SIZE P215/64R15/N WOL R/PE ST TL HWY
DH6 MIRROR I/S, SUNSHADE,ILLUM,LH_RH
AR9,SEAT,FRT BKT EUROPEAN STYLE PASS A DRIVER RECL
The rest i could'nt find. Hope this helps you out
Old Aug 22, 2008 | 02:13 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: RPO Code Help
Yes, thank you. I'll have to try searching some more when I get home from work for the rest I guess.
Thanks again.
Old Aug 22, 2008 | 03:11 PM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Re: RPO Code Help
As for the "82M" code.... all the "82" codes are interior trim color codes. 82 is Medium Grey; I have no idea about what the "M" specifies.
As for the "I9Q" code.... all the "I" codes in my books are listed as "Trim, Interior Design". This one would be I9Q - Trim, Interior Design (9Q).
If it is instead 19Q, then that would specify "Molding Color, Black".
This is all according to what I have here in my records, of course....
Old Aug 22, 2008 | 05:33 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: RPO Code Help
Thanx, Frankie. Anyone have any idea about QHY? According to what I have, its the RPO for light truck tire??
Old Aug 22, 2008 | 10:29 PM
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Re: RPO Code Help
Sure....
"QHY - TIRE, P205/70R14/N BL R/PE ST TL ALS"
Looks like the code for a blackwall, all-season 14" radial tire to me.... looks like it could have been used on possibly either a base Camaro or a Berlinetta model. Hope that helps.
Old Aug 23, 2008 | 08:45 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: RPO Code Help
That makes sense. It's from a Berlinetta that has 14" rims on it. I have no way of knowing if they are the originals of course, but it makes sense now. Guess the list I have is a little off. Thanx again.
Old Aug 23, 2008 | 09:01 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: RPO Code Help
http://www.chevy-camaro.com/chevy-camaro-RPO-Codes.asp
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
