Where might i find my RPO codes in an 82 T/A
Old Sep 19, 2008 | 12:05 AM
ndamron's Avatar
Car: 82 Trans-Am / 83 Trans-Am
Engine: Major Mod SBC / Minor Mod SBC
Transmission: Major Overhaul 700R4 / Stock 700R4
Axle/Gears: None!!! / 3.73 posi disc...soon
Thanks all
Nick
Old Sep 19, 2008 | 12:29 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Where might i find my RPO codes in an 82 T/A
82-89 have it in the center console, 90-92 have it in the rear storage compartment. I might be wrong and its 82-90 and 91-92, but yours, being an 82, will have them as a sticker in the center console. If there is nothing there, you're out of luck.
Since you have a Pontiac, you can check here http://www.phs-online.com/ and order a complete kit on your car.
Old Sep 19, 2008 | 12:53 AM
simo's Avatar
Car: 1983 Daytona 500 Pace Car
Engine: CFI - 305
Transmission: Automatic-700R4
1984 was the first year to have the RPO's in the center console.
Old Sep 19, 2008 | 06:24 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The best thing the '82-'83 cars all have is a trim tag. On Camaros it's located on the top center of the radiator support and it's probably similar on the Firebird. This will give info on paint color/type,interior color/trim style,seat style,if factory T-Top car CC1 will be present along with some other trim codes.
You may be one of the lucky ones to find a build sheet which will give you all the information for your car. This can be found in the seats,under the carpet,behind door or trim panels or it may not have been left in your car at all.
Old Sep 19, 2008 | 08:05 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
Just as Simo and Coolram62 said. Check the build plate on your radiatior support.
The RPO stickers did not start until 1984.
Old Sep 22, 2008 | 10:24 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
If you want to look for the build sheet which has all the options listed, try under the drivers seat. That is where I found mine. They could be anywhere though, under the carpet, behind door panels, under the dash, above the gas tank...I have heard many different places it could be but it seems to be more common under the seat. Be careful though, they are usually torn and deteriorating so if you find it, handle with care.
Old Sep 23, 2008 | 01:51 AM
Kevin91Z's Avatar
Oh, I guess I learned something today! I should stick to the 89-92's that I know the best.
Thanks for the clarification.
hectre13
Dec 11, 2023 08:14 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Regal105
Aug 23, 2015 03:45 PM
Randomtask2
Aug 13, 2015 01:57 AM
antares57
Aug 6, 2015 07:47 AM
