What wheels are these?
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
I have seen these before but I don't remember what year formulas had them.
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: What wheels are these?
They were used on the '84 15th Anniversary Trans Am(painted white), '85-87 Trans Am with WS6 suspension option(painted gold or natural) and '87 Formula(natural).
Thanks for the fast reply guys.I didn't know that 16" wheels were avail. in 84.
The color of inserts on these are like a charcoal grey.Is that what natural is?
Car: 89 Formula
Transmission: TH 700R4
yes. I have newly restored set on my 89 Formula--looks like an 87 with the wheels--but thats what I wanted.
kinda thinkin about cleaning them up and stickin them on my 89(92 clone)
not sure yet.
not sure yet.
I've checked Modern day muscle and ebay with no luck.
If anyone else reads this and has any idea please let me know.
Axle/Gears: 9-bolt/3.45
The wheels were offered on all the years and models mentioned in the above posts, but on the Formula, they were available for one year only, the first year, 1987.
Car: 89 Formula
I found an NOS set on ebay for mine. As of a few months ago they seller had a 2nd set but have not seen them since.
They were $$$ 275.00 or so.
Sellers name on ebay is rohnaz if you want to contact and follow up
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
See if a set of IROC center caps would fit, and if they do, these should fit as well.
http://cgi.ebay.com/ebaymotors/Chevy...mZ270279090879
anyway,I'll try one out if I can find them!LOL! I sold that car 4 years ago.
No telling where I stuck the extra caps.If they fit then I'll go with a set of those you posted above.If not,I'll try my luck with a j/y or fabricate something on my own.After all,theres nothing special about them.
Just a 2"piece of machined alum. should do the trick,if that is the size of the opening on these wheels.
The diameter of the face of the cap is 2 1/2", and the diameter of its lower plastic structure that snaps into the wheel hub opening is just over 2 3/8".
But didn't you say you only need one? So you apparently have three, which means you can use one of them as a template, if you try to have some made.
If you go junkyarding, plan to hit several yards, if there are multiple yards available to you. And don't get discouraged if you don't find any right away. It might take many visits to many yards over many months. So be patient.
Oh, and to answer one of your questions that nobody answered yet: yes, the inserts were painted a charcoal color in the clearcoated, natural-finish, machined wheels.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I KNOW I will get stoned for this...
Like stated above...
The 1984 Anniversary Ed T/A
They were the WS6 Wheels on the Trans am from 1985 - 1987
They were the standard (and only) wheel on the formula in 1987...
SOME not many, In 1988 EARLY EARLY Formulas may have gotten them, I have seen a couple 88 cars that had them, and they were all early 1988 Formulas... The parts & Illustration catalog also has them listed for 1988...
John
John
I bought them on the spot and hauled them to my truck so,I guess one of them had some broken tabs on the back that would cause it to just go missing.Fell off on the way to the truck?Only answer IMO cuz theres no centercap in the bed of my truck.
and yes LA,I did figure out the painted/natural thing.thanks!
I'll make a complete set using tinfoil and beercaps before I spend $275!!
John
John
Does the parts & illustration catalog show the same size opening for the centercaps as the iroc wheels?(ask Scott Moyer)he probably dreams these numbers!He could probably read off the exact dimensions in his sleep!LOL!
just joking Scott!
I believe the early 88 theory you posted.
In late 87 they probably had a few lots of the production 87 wheels and found an easy way to get rid of them instead of scrapping them.
The 14" and 15" versions of this wheel used on other Pontiacs have smaller hub openings than the 16" version used on Firebirds, so you can't use centercaps from those for measurements.
I don't know how far away from you the seller is, but given how hard-to-find the centercaps are, have you tried calling him to see if he would look for the cap? You might even drive back to look for it yourself... if you haven't already done those things.
The dimensions I gave you above are from one I have sitting right here at my fingertips. It's one I'm hanging onto for my own "just in case" moment, otherwise...
And, John, based on parts' data I've seen, this wheel continuted to be used on WS6 TAs through 1989. The GTA wheel was optional for the TA, but this was still its standard WS6 wheel. So that might also explain why it's listed in parts illustrations catalogs after 1987.
I say you just take one for the team and send me that spare in your fingertips.Just kidding.
I popped one of my three out tonight and theres no way the iroc ones would work.
And LA,I have no clue where the seller of these wheels lives.
I picked them up at a central fl. swapmeet that is held first sunday every month at a county fairgrounds.The main field is the parking lot for the shows.So,if the cap hasn't been ran over 100 times since sunday,chances are that some 5 year old kid has it stuffed in his pocket with his favorite hotwheels car!LOL! and the fairgrounds is about 50 miles from my house.
So theres no hope in finding that one IMO.
Turkey run at Daytona is coming soon so I'll try my luck there and the classifieds here.Thanks again,Tim
However I have seen 1988 T/A's with the WS6 that got the Dished style Formula wheel... The guy was the original owner but IIRC the SPID sheet called out the Black cross laced style wheel. I suspect that there may have been a brief shortage, or there was an option, I have not delved that deep into it yet to get any substantial conclusions. I SUSPECT that there may have been brief shortages and instead of stopping the line they simply swapped wheels at the factory to keep things going, as that was more common than some of us want to accept.
ok,I know this thread is old and lame now but,been trying here on the classifieds with no luck and I'm hitting the turkey run tom. morning!
Maybe I'll have some luck there.
Thanks all for the help so far.
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
I did'nt want to get rid of it but I have one, still on the rim that was on my gta(the guy lost the original rim) I dont know whats it worth??
drptop70ss
Oct 4, 2015 09:44 PM
punkmaster98
Sep 8, 2015 09:45 PM
