Surface scratches on side windows and rear hatch
Car: 2010 2LT RS
I have an 87 IROC I just recently acquired. I want to get the windows tinted but have been holding off till I decide how I'm going to remedy the situation I have on hand. I have light surface scratches on the inside side door windows and the outside rear hatch glass. I've had this problem on my 87 Corvette and had to replace the side windows due to the outer window strips becoming brittle with age which caused the scratches. The only difference though is that those scratches were deeper on the Corvette. Now on the IROC.. They are not deep. What would be the best way to resolve this. Can I buff out those scratches? If so then what do I use and what do I need?
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Re: Surface scratches on side windows and rear hatch
I was thinking I would like to know the same thing myself...scratches on my side windows.
Car: 2010 2LT RS
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I was just going to suggest eastwood.
www.eastwood.com
http://eastwood.resultspage.com/sear...&submit=Search
www.eastwood.com
Car: 2010 2LT RS
Thanks for the replies. I checked on the eastwood site and there seems to be a lot of negative feedback about some of these products. I'm a little worried about having to order something that may not be satisfactory. Any other suggestions?
Car: 1991 Trans Am
Engine: 5L TPI
The glass shop I go to, whom I trust due to the work they've done on more than one windshield of mine, told me some advice on their glass polishing option. They said that basically, if your fingernail catches on a glass scratch they will not be able to completely buff it out. Glass like that will just need to be replaced - maybe with a JY piece.
Car: 2010 2LT RS
Car: 1991 Trans Am
Engine: 5L TPI
A quick search of http://car-part.com/ sez... about $50 for side glass, $100 for heated rear glass, here in sunny Michigan
Car: 2010 2LT RS
Car: 1991 Trans Am
Engine: 5L TPI
Bump
