L69 Blower Kit
Old Mar 9, 2009 | 11:34 PM
simo's Avatar
Car: 1983 Daytona 500 Pace Car
Engine: CFI - 305
Transmission: Automatic-700R4
L69 Blower Kit
N/A
Old Mar 10, 2009 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: L69 Blower Kit
I've heard about the 'fix'. Could you snap a few pics of the pieces out of the box?
JamesC
Old Mar 10, 2009 | 01:11 PM
f1ls1's Avatar
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
Re: L69 Blower Kit
There were three different fixes for the Vapor lock problem. Pontiac used a bigger fuel pump the same pump was used on the sbc 400.Chevrolet used an electric intank fuel pump to feed the engine mounted pump. And you had the blower kit which was worthless. Either of the first two I listed works the best.
Old Mar 10, 2009 | 06:42 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Re: L69 Blower Kit
Where does this thing mount??
Old Mar 10, 2009 | 06:53 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: L69 Blower Kit
mounts under the RH fender,about in the area
behind the marker light,hose comes out behind
battery. Found one of these blowers installed on an
'84 L69 z28,blower motor had late '85 date code on
it,was probably installed in 1986.
BTW the same blower is found on v6 fieros-used
to blow cooling air on the coil and alternator.
Old Mar 19, 2009 | 02:00 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: L69 Blower Kit
The blower kinnda looks like the kind my 78 Nova had for the rear window defogger without the hose of course.
Old Mar 19, 2009 | 09:30 PM
David M's Avatar
Car: '84 Z28
Engine: L69
Re: L69 Blower Kit
Very cool! I always wondered what these things looked like in the box. My '86 LG4 Z28 had one of these, and I didn't know what it was until I sold the car! Thanks for the pics.
Old Mar 19, 2009 | 09:54 PM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Re: L69 Blower Kit
So how do we know what fix each of our cars have? I highly doubt I have the blower as I don't think I see it on my car. But I don't recall any problems and Dad never mentioned anything about the carb having problems.
Old Mar 19, 2009 | 10:30 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: L69 Blower Kit
Look at the relays next to the brake booster. If there is relay mounted to a L-shape bracket and looks out of place the car has the in-tank pusher fuel pump. '84's L69s produced about mid-year and up will have this installed from the factory.
Another fix was a carb base gasket with a big built-in metal heat shield.
Old Mar 19, 2009 | 10:54 PM
L695speed's Avatar
Re: L69 Blower Kit
Well with my car being built in July I would say theres a good chance that I've got the in-tank pusher fuel pump fix. I don't see anything in the photos I have that show the relay but I do remember some weird stuff back there.
Old Mar 24, 2009 | 10:20 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Re: L69 Blower Kit
Apparently I have the 3 psi electric fuel pump in the tank after some searching. Funny though, in my owner's manual, it mentions the blower for the carb.
Old Mar 27, 2009 | 10:10 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: L69 Blower Kit
Interesting,
My 87 Formula LG4 did not have anything like that . What it did have was an in-tank fuel pump and a Mechanical Fuel pump on the front of the engine.
John
Old Mar 30, 2009 | 03:05 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Re: L69 Blower Kit
Yea, your lg4 and mine are the same with both the mechanical and electric fuel pump.
Old Mar 31, 2009 | 10:07 AM
MOTOCROSS's Avatar
Car: 1984 Z28
Engine: 355
Re: L69 Blower Kit
So, if your electric fuel pump goes out, can the mechanical pump pull enough fuel through it to feed the motor? My fuel pressure drops after the motor warms up. Still runs OK, but I don't like it. I have an 84 Z28 L69. Now has a strong 350 with Holley 750 and a Holley mech fuel pump. Any suggestions??
Old Mar 31, 2009 | 03:56 PM
okfoz's Avatar
Re: L69 Blower Kit
I think the mechanical pump is more or less adequate, however the problem with the engine mounted fuel pump is it creates a low pressure while sucking fuel from the tank. With the lower pressure it actually increases the chances of vapor-lock or boiling. Any liquid will boil at room temperature when put under enough vacuum, you add that to the small engine compartment and the exhaust so close to the fuel lines and it's a problem waiting to happen.
Keep in mind that they did not completely drop the L69 as they used the engine in the Monte Carlo until the end of the 1987 MY.
The in tank FP will reduce this because it is increasing the pressure to the carb. If you want to increase the pressure, the in-tank fuel pump is not a bad idea...
Old Aug 11, 2012 | 12:00 AM
the209bnr's Avatar
Car: 1984 Pontiac Trans Am
Engine: L69
Transmission: THM-700R4
Axle/Gears: 3.73 Posi
Re: L69 Blower Kit
subscribed
Old Aug 11, 2012 | 11:02 AM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
Re: L69 Blower Kit
Do you have any pictures of relay location and was the carb gasket a OEM gasket?
Frank
Old Sep 11, 2012 | 09:28 PM
Jon Friesen's Avatar
Car: 1986 Z28
Engine: stock 305
Re: L69 Blower Kit
I had the dealership install the blower kit on my '86 Z28 Lg4 right after I bought it new in '86. It still comes on after the car has been shut off. It does stop the car from surging when it is hot.
Old Sep 13, 2012 | 02:59 AM
the209bnr's Avatar
Engine: L69
Re: L69 Blower Kit
can you post up pics of this inside of the vehicle engine bay?
Old Sep 14, 2012 | 08:06 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: L69 Blower Kit
Oh, that's what that was!
I had a parts customer came to the shop with that running non stop. We couldn't figure out what it was doing there. His was an lg4 87 5 speed firebird.
Pete's 89 GTA
May 14, 2011 04:13 PM
JCL91TRANSAM
Sep 6, 2008 03:10 AM
BuckeyeROC
Jul 2, 2002 10:18 PM
Ukraine Train
Mar 6, 2002 01:58 PM
