what type fuel pump in LG4?
Old Feb 26, 2002 | 06:45 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
Did the LG4 originally come with a mechanical fuel pump or a low volume in-tank one?
Old Feb 26, 2002 | 07:36 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
mine has a mechanical pump......i'm guessing that this is added by the previous owner though
Old Feb 26, 2002 | 07:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My 85 IROC LG4 has a mechanical. I replaced it a few weeks ago with a stock replacement.
JamesC
Old Feb 26, 2002 | 04:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't know that I've got the straight story, but what I've HEARD is that a dealer-installed anti-vapor lock kit was available that put in the in-tank pump and added a fan to blow air onto the carb when the engine was shut off. My donor car had the blower, but as far as I know, did not have the in-tank pump. The other part of the story is that all '87's got the in-tank pump along with the mechanical pump on the block.
The Chevy High Performance magazine article series "My Generation Camaro", an '87 LG4, apparently had the in-tank pump, but no mention was made of the blower. They did talk about a weak mechanical pump that they replaced to get it running right.
Old Mar 6, 2002 | 07:10 AM
Car: '87 Camaro LT
Engine: 355 L98
i haven't checked at the gas tank yet but there's a connector for an oil pressure switch in the harness so i'm assuming there's an in tank pump? if there is should i also put on a mechanical one? either way do i need a pressure regulator for the electric pump?
Old Mar 6, 2002 | 10:11 AM
five7kid's Avatar
You should use a mechanical pump that includes the return line. The pressure is regulated by a relief valve inside the mechanical pump, to the return port, so no regulator is needed.
CHP didn't do that, just used a standard two-port performance pump; not sure how they got by with it (could be the electric wasn't working, and they were just sucking through it - might explain some of their problems).
Old Mar 6, 2002 | 01:27 PM
Car: '87 Camaro LT
Engine: 355 L98
should i use the mech. pump along with electric then? or just mech?
Old Mar 6, 2002 | 01:58 PM
five7kid's Avatar
If the electric works, I'd use both.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
92camaroJoe
Aug 13, 2015 06:07 AM
