Actual car?
Old Mar 20, 2009 | 01:20 PM
worxsinprogress's Avatar
Actual car?
I was told by a 3rd gen camaro owner that during the 84 TA production, the factory messed up and decked some of the 305 blocks too much raising the compression to more than the HO. This is the only time I have heard of this. Just wondering if it happened or if it is just a rumor. Thanks.
Old Mar 27, 2009 | 10:14 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Actual car?
That is a first I have ever heard of it.
One thing to consider is if you mill too much off of the top of the block and too much off the heads the intake will not seat correctly.
It sounds like a rumor. Kind of like some 350's accidentally being installed with the TPI in 1985. They were all 305 cars, but performed like a 350.
John
Old Mar 28, 2009 | 12:15 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
Re: Actual car?
Sounds like one of the many lines of BS associated between backyard hacks and these cars. I had a guy with a big smile and a straight face try to tell me that the only difference between a 305 and 350 were the heads.
Old Mar 28, 2009 | 01:27 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Actual car?
WTF!?!? Complete Idiot.
Old Mar 28, 2009 | 01:35 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: Actual car?
no, its true!!!!!
they have the same numbers and everything!
3-0-5
3-5-0
its a conspiracy i tell you.
(someone slap me now)
Old Mar 30, 2009 | 09:16 AM
okfoz's Avatar
Re: Actual car?
I guess it would be true if you had dyslexia.
Armored91Camaro
Aug 12, 2015 09:41 AM
mx127
Aug 10, 2015 08:13 AM
gwade12
Aug 8, 2015 08:17 AM
kyle5647
Aug 7, 2015 03:08 PM
