How rare is this?
Old Apr 27, 2009 | 08:56 AM
dranate's Avatar
Car: 1986 camaro, 1992 and 1994 saturn
Engine: 305 wanting a 350
How rare is this?
sI have a 1986 chevy camaro and right behind the autoshifter is a number keypad for the security system I just wanted to know about that is it factory and how many where made like that.
Old Apr 27, 2009 | 08:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: How rare is this?
Never heard of an OE.
JamesC
Old Apr 27, 2009 | 09:07 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Aftermarket.
Old Apr 27, 2009 | 11:57 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
There was a dealer installed alarm that was a GM piece that had a keypad, it is possible it is one of those.
Old Apr 27, 2009 | 12:01 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
I note you have a 9 bolt with a 3.70 so you must have been in there. Do you know who makes a locker or Helical gear LSD for those diffs?
Old Apr 27, 2009 | 12:15 PM
Klortho's Avatar
Car: 1987 GTA
No I don't, the only place I've ever found any replacement parts is at http://www.9bolt.com however, the rear is factory from an '85 T/A with the L69 with the 3.70 gearset in it.
Old Apr 27, 2009 | 12:27 PM
dranate's Avatar
But how common was this? Whats a rough estimate of how many have this feature?
Old Apr 27, 2009 | 12:30 PM
JamesC's Avatar
Probably no way to tell.
JamesC
Old Apr 27, 2009 | 12:38 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
It was a dealer installed feature. There could be thousands in NY, CA and Chicago and none for th erest of the country. No way to know what the dealer installed. It was not a factory option.
Old Apr 27, 2009 | 01:01 PM
my82roc's Avatar
Car: 89 Iroc Convertible
I had one in my 88 sport coupe.You had to turn the key forward to the on position,put in a 3 digit code and then you could start the car.If you didnt do that nothing would happen when you tried to start it,not even a click
Old Apr 27, 2009 | 04:08 PM
1brd2brd3brd4's Avatar
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
Remember........RARE does NOT mean something is worth more money. Great convesation piece maybe.....
I have an 88 T/A with a factory aluminum drive shaft. I have never seen another 3rd gen with one or heard of anything other than a 1LE camaro having one.I dunno what it means.......I just have it. Car seemed to have been loaded from the factory, but no 350,no disc brake rear, no G92. But it did have aluminum space saver spare and aluminum brake drums. Whats it mean? Not a lot that I know of ,but its mine
Old Apr 27, 2009 | 04:45 PM
JT's Avatar
JT
Community Administrator
Off topic but my 1988 Trans AM has the aluminum drive shaft (JG1), 305 TPI and drum brakes. It's "loaded" with the digital dash and T-tops. Sounds similar equipped as yours. I can post a picture so you can say you've seen another
I don't think the JG1 is exactly rare. The majority of all GTAs came equipped with it.
Old Apr 27, 2009 | 05:22 PM
JamesC's Avatar
Not rare at all. Without trying particularly hard, I sold 60+ of them at one point. While 1LE's were equipped with them, so were many other cars.
JamesC
Old Apr 27, 2009 | 08:26 PM
Good to know. I have an 88 GTA and it has the steel drive shaft. I have cut up 20 or more camaros/firebirds and its the only one I have ever come across. Dont know if its rare. Dont really care. I was just tring to make a point that something you have never seen before dosent make it rare and you have helped me prove my point. Different parts of the country got different types of options. I also have a hatch with a wiper on it.(not on my car just have it laying around off a junker I cut up) just goes to show there are a lot of odd things out there.And if you read that last post again.........I never said my car was rare.........I said it was the only one "I" have ever seen.It's not too often you get to see a cars drive shaft while going down the road.........
Old Apr 27, 2009 | 08:45 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I dunno how rare that would be.. but in autoshop I remember cringing when a kid with a 91 Firebird 'Vert removed his stock Delco CD player for an alpine deck, cut out the rear panels for 6X9's, and stuck a tach on the dashboard.. L03 Auto car, nice green, too.
Old Apr 27, 2009 | 09:06 PM
JamesC's Avatar
....just goes to show there are a lot of odd things out there.
Not arguing with what you say (my only point was that alum shafts aren't rare). BTW, I have the rear wipe/washer option on my 85. It's also equipped with a console clock.
JamesC
Old Apr 27, 2009 | 09:51 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
i have one that has a clock in the console!..Rare?
Old Apr 28, 2009 | 05:13 AM
UGH!!! I never said these were rare!
Old Apr 28, 2009 | 07:31 AM
JamesC's Avatar
JamesC
Old Apr 28, 2009 | 10:48 AM
I'll agree to that!
Old Apr 28, 2009 | 02:38 PM
mr396's Avatar
Car: 2003 BMW E46 M3 Vert
Engine: 3.2 I6 M power 333 h.p.
Transmission: SMG 6 speed
Axle/Gears: 3.62 posi
I found this about the JG1 in the Camaro musclecar color-history .
Old Apr 28, 2009 | 08:32 PM
That makes sence and makes no sence all at the same time.........I have an 88 GTA also.T-top, 9 bolt, no aluminum shaft. Only come in drum brake cars? guess so, doesnt matter. I have never seen a car with a key pad security system( Maybe that will get us back on topic)
Old Apr 28, 2009 | 09:43 PM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
Post us a pic of the keypad if you will.
Old Apr 29, 2009 | 03:47 PM
87_Injected's Avatar
Car: 2010 2LT RS
Old May 2, 2009 | 07:40 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
Originally Posted by 87_Injected
Old May 7, 2009 | 10:14 AM
dranate's Avatar
Iwill post them tonight after work im at school right now I dont care about money but my car is in need of a little work and I am thinking of selling it but I dont know right now if its a special car then I might keep it for a little longer
Linson
Oct 24, 2025 02:00 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Lbibb
May 5, 2016 12:00 AM
okfoz
Oct 13, 2015 02:19 PM
sjorgens
Oct 1, 2015 07:54 PM
