looking for compatible Iroc parts
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I just got a 1990 Iroc and new to this type of car. If anyone can tell me what parts and years will interchange,it will help me out alots hope to get started restoring in couple of weeks,
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Re: looking for compatible Iroc parts
most parts from 82-92 are interchangable with these cars, All but fenders & dashes I do beleive.
Some interior is 82-92, while the dash in yours is only 90-92. The body is swappable for 82-92 with just minor changes. Depends on what you need. There are also engine differences between serpentine belt setup or Vbelt setup, MAF or MAP, etc. Do you have any specifics that you are looking for?
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thanks for the info narrows my search. I know the pass side mirrow is busted.The dash is cracked and the pass side rear spoiler is busted I dont know if I can repair anything or replace it .
Any 82-92 manual side mirror is the same, however, power mirrors have different wiring so you would need one from an '87 or later car. You need a passenger side spoiler section from an 87-90 car. If it's your dashpad that's cracked and 82-92 pad will fit. If it's the dash itself you'll need one from a 90-92 car. I'm sure we have a lot of the parts you need available on our website.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
'82-'84 Camaros have different dash pads than '85-'92 Camaros, but they are still interchangeable.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
More info thanks, now I will start looking around at the years you all stated this is going to be a good project I will try and keep it as original as possible Thanks again Dustytrix
mustangman65_79
Aug 11, 2015 03:17 PM
82, 91, 92, camaro, camaros, compatibility, compatible, dash, engine, firebird, firebirds, generation, interchangeable, iroc, pad, transmissions
