paint codes for valve covers
Old Aug 26, 2009 | 05:44 PM
deus402's Avatar
Transmission: 4l60e (700r4)
Axle/Gears: 4.10
i am restoring my 86 z28, and the valve covers and engine paint were in bad shape. is there any info out there on correct paint codes for the valve covers, heads, and engine block?
Old Aug 26, 2009 | 05:50 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: paint codes for valve covers
the block/heads/intake/oil pan is simi gloss black engine paint
the valve covers the aluminum engine paint may be close, bring a valve cover to the auto parts house and try to match it up
Old Aug 26, 2009 | 09:29 PM
deus402's Avatar
Axle/Gears: 4.10
i have already painted the block and oil pan a semi gloss engine enamel. intake? that is just cast aluminum with no paint, mine is pretty dirty, but i am pretty sure it was originally painted.
as for the valve covers, i have already hot tanked them so i can't just take them in and try to find a match, plus, i was hoping that someone out there would have the actual correct paint code.
Old Aug 26, 2009 | 11:47 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
My suggestion is to go to your local dealership with you vin. I asked about the paint code for the black trim around the rear hatch, etc. When I gave them my vin, I got the paint code a few days later. That may also work for the valve covers. An engine code would probably be more specific and therefore more accurate.
Hope that helps.
Old Aug 29, 2009 | 01:25 AM
deus402's Avatar
Axle/Gears: 4.10
DAVID,
I CALLED GM IN ORDER TO GET THE INFO YOU REQUIRED AND THEY HAD NO RECORDS OF THE PAINT CODES FOR THAT AGE OF VEHICLE AND MY CATALOG DOESN'T PROVIDE THAT INFO.
THANK YOU,
Chris XXXXXXXXX
H&H CHEVROLET
no dice from the dealership....
anyone else have any ideas?
Old Aug 29, 2009 | 11:07 AM
89RS_82Z's Avatar
maybe someone with factory paint on theirs can help you match it up to a rattle can color
give classis indus, year one, or hawks a call also
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
1985chevydude
Aug 20, 2015 12:29 AM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
