Trans am Rim question
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
So im at work and looking for a quick answer, i searched but i guess im not using the right keywords.
My rim is bent and im in need of a new one, i just had tires put on my car and told them to check for front and rear specific rims, but i personally do not know. I need a new rim and was wondering if Trans Am rims have different offsets like some iroc wheels had. My car is an 87 and as far as i know everything is original to the car.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Trans am Rim question
Trans Am wheels have 5.25 backspace for the front, and the Rears are 4.75..
I think the offset may be a little different, but they will bolt right up and not rub at all. all 3rd gen wheels are interchangeable.
Alright, i guess ill have to see which rim got bent, a front or rear. But i dont have any rubbing or anything so im assuming they got it right, i was jw though.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I know that most people like putting front wheels on the back, because they have a nicer lip and you can rotate your tires as well.
Car: To many to list
before you go pulling the rims back off..Do you have 15" or 16" wheels? The 15" were not specific to front or rear.The 16" were specific
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The only thing is a Front will fit on the rear all day long, the rears will not fit on the front.
I never considered that the 15" rims were the same on all 4 corners... something to look up.
John
John
84z96L31vortec
Aug 20, 2017 12:16 AM
