Do I have a california car?
Old Feb 2, 2010 | 06:01 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Last week I was replacing my heater core, and I found a parking pass from Disneyland (Anaheim, CA) inside the heater ducting. So I know the car has at least been to CA. Also, the PROM code is AKHK, which is listed as california emissions. I can't be sure if it's original, but it is the correct year, transmission, and axle ratio for my car, so I assume it is. Is there any way to find out for sure? I'm thinking of pulling a carfax report to see where it was originally sold. Also, what all is different about the california PROM, and the car in general? I thought the CA cars had dual cats, but I only have one. Maybe only the 350 cars got the dual cats?
Old Feb 2, 2010 | 06:10 PM
Guest
Guest
Posts: n/a
Re: Do I have a california car?
There is not enough of a difference worth talking about. I think on 86 the prom and the vacuum valve for the charcoal canister are different. Also, many of these were made and sold with the so-called 'california' emissions package anyway, regardless of where they were. That would not mean it was definitely sold in CA.
Old Feb 2, 2010 | 06:13 PM
Yor's Avatar
Yor
Car: 1984 15th Ann. T/A
Engine: 350 Goodwrench
Transmission: T5 (Not factory, possibly rebuilt)
I'm no expert, but I read, a lot, when it comes to Technical data on Camaros/Firebirds.
If you're just looking to see if it was MADE it California the 11th Vin number/letter should be a L, which is the Van Nuys plant. As an 88 I believe ALL camaros and firebirds were made there, as they closed the Norwood plant the previous year (vin N specified the Norwood plant).
Not sure if that's what you're looking for per-say, but as for the dual cat option, N10 was the RPO code, and I believe it was not required in California emissions suprisingly, apparently adding the 2nd cat increased HP by roughly 10, and was only on L89's if I remember right..
Like I said I'm still a bit of a noob with 3rd gens, but I know quite a bit from research I do for the sake of doing it. lol.
None of what I'm talking about really has to do with where it was sold, but I'm assuming you could look that up somehow with your VIN
and whatnot.
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
3rdgenparts
Aug 6, 2015 09:03 AM
