Correct P/Ns for my seat belt parts?!
Subscribe
Feb 22, 2010 | 09:05 AM
So far I only have been able to find these:
$62.83 - 12504435 - Front Seat Belt Receiver - Grey
$54.08 - 12500493 - Seat Belt - Grey
My question is, the receiver, is it the same P/N for both sides? Same for the seat belt?
I only need the front receivers and belts, my rears are like new.
Thanks!
Reply 0
Feb 22, 2010 | 11:59 AM
Re: Correct P/Ns for my seat belt parts?!
The short answer is no. One side is longer then the other. Couldn't tell you which is which without looking at a car, but driver/passenger are different. If I had to guess it's because of the bump on the passengers side floorpan for the catalytic converter.
The belts are different too... they're mirror images of each other.
Reply 0
Feb 22, 2010 | 07:42 PM
Its normally the drivers side buckle which is the longer one.
Reply 0
Feb 27, 2010 | 01:29 PM
Thanks!
12500493 is the driver front grey male seatbelt
12500494 is the passenger front grey male seatbelt -this part should still be available if you look hard enough
12504434 is the passenger front grey female seatbelt - this part is discontinued and impossible to find new. You best bet is to find a mint used one. As other people have stated, the passenger belt is shorter than the driver one. I do know of one place that has one for sale but their parts tend to have shelf wear or other issues and I do not like buying from them. If you want their contact info, email me at andy91gta at hotmail dot com.
For the female belts, there are also 2 grey plastic covers for the torx bolts that are not included. I do not know the part # for those. I bought 20455841 thinking they were the right ones but they aren't, they are a dark grey. If you come across the correct part number, I'd appreciate it if you let me know.
Reply 0
Feb 27, 2010 | 11:16 PM
I could use the part numbers for the female gray seatbelt also. I found 1 for $80 but its not worth that to me, and they don't give out the GM part number. If you find them, could you post them?
Reply 0
Mar 15, 2010 | 10:58 AM
Ok, so just to recap before I start searching to order, I need:
12500493 - Driver front grey male seatbelt
12500494 - Passenger front grey male seatbelt
12504434 - Passenger front grey female seatbelt
I don't need those cover boxes you mentioned, mine are still good.
What is the PN for the Drivers side female seatbelt that is missing from above?
Also the first 12504435 PN is for the receiver for both sides that is still available. Is this the short one or the long one? Does anyone know the correct PN for the one that is not available so I can still try?
Thanks!
Reply 0
Mar 31, 2010 | 10:31 AM
BUMP
Reply 0
Mar 31, 2010 | 01:42 PM
Quote: I could use the part numbers for the female gray seatbelt also. I found 1 for $80 but its not worth that to me, and they don't give out the GM part number. If you find them, could you post them?
IF YOU CAN GIVE ME THE LAST EIGHT OF YOUR VIN # I WILL TRY TO LOOK UP THE PART NUMBER FOR YOU AND SEE IF WE CAN FIND ONE.
Reply 0
Mar 31, 2010 | 01:56 PM
12504435 IS THE DRIVERS SIDE
12504434 IS THE PASSANGER SIDE
Reply 0
Mar 31, 2010 | 02:44 PM
Quote: IF YOU CAN GIVE ME THE LAST EIGHT OF YOUR VIN # I WILL TRY TO LOOK UP THE PART NUMBER FOR YOU AND SEE IF WE CAN FIND ONE.
NL205379
Reply 0
Mar 31, 2010 | 02:45 PM
Awesome! I just placed my order! Only part I couldn't find was the 12504434 which I posted a wanted ad for:
https://www.thirdgen.org/forums/inte...seat-belt.html
Reply 0
Subscribe
