1LE question????
Old Feb 27, 2010 | 05:50 PM
t/a formulas's Avatar
Car: 83 t/a , 89 Formula
Engine: t/a-455 Olds, formula 305
Transmission: soon to be 4 speed, 700r4
Axle/Gears: 2.77, 3.23
1LE question????
I know a junkyard out of town that has about 25 camaros/firebirds and
I was wondering if there is a check list of special parts only on 1LE cars,
what can i look for to be sure its a 1LE? or another rare option??
Old Feb 27, 2010 | 06:13 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Re: 1LE question????
Well, the chances of finding a 1LE car in the junkyard are extremely slim. However, the quickest way to spot one in a junkyard would probably be to look at the front brakes because they are complete different from non-1LE cars.
Old Feb 27, 2010 | 09:28 PM
Drew's Avatar
When you get down to it, the only special part on 1LE's are the front brakes. Everything else is normal late thirdgen hardware or base model hardware.
Old Feb 27, 2010 | 10:51 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
Drew is right. Its just brakes.
Below is "just brakes" part numbers:
1988-1992
Fuel tank: 10121026
Fuel sender unit (longer): 25094804
Fuel strainer (double screen): 25121120
Fuel Pump: 25116163
Aluminum driveshaft: 10085375
AC delete pulley: 10115875
Suspension
Front strut: 22064153
Front sway bar (36mm): 14094344
Front sway bar bushing (36mm): 14094388
Front brace (frt end sheet metal radiator opening): 14039401
Front coil spring (code CDB): 14029396
Front steering knuckle LH: 18016737
Front steering knuckle RH:18016738
Rear lower control arm: 10164151
Rear lower control arm bushing: 10164152
Rear shock absorber: 22064149
Rear sway bar (24 mm): 10035033
Rear sway bar bushing (24 mm): 10037105
Rear coil spring (code NNL): 10018091
Brakes
Master brake cylinder: 18014286
Master brake cylinder piston (secondary): 18006832
Proportioning valve (2nd design, 1.5 tube nut threads): 10136840
Proportioning valve (1st design, 1.0 tube nut threads): 14089496
Front caliper bolt: 14084051
Front caliper bracket: 18016034
Front caliper retaining clip: 10132842
Front caliper LH: 10132827
Front caliper RH: 10132828
Front caliper guide pin: 10140666
Front caliper anchor plate LH: 10132829
Front caliper anchor plate RLH: 10132830
Front caliper bolt washer: 14080254
Front caliper hose LH: 10113075
Front caliper hose RH: 10113076
Front brake hose to caliper bolt: 14047782
Front brake hose to caliper bolt washer: 14076180
Front rotor (w/ hub and studs): 18016035
Caliper bleeder cap: 14089150
Front caliper bleeder: 14071826
Front caliper piston: 10104482
Front brake caliper guide pin boot: 14067552
Front hub outer bearing: 457049
Front brake pads: 10104485
Rear caliper plate and bracket bolt: 10112649
Rear caliper guide pin bolt: 14067559
Rear caliper mount bolt: 10097602
Rear caliper housing w/ piston LH: 10132831
Rear caliper housing w/ piston RH: 10132832
Rear caliper guide pin: 14067560
Rear caliper anchor plate: 10112652
Rear brake caliper guide pin boot: 14067552
Rear brake hose: 17688596
Rear brake hose to caliper bolt: 14047782
Rear brake pipe bracket: 10097601
Rear brake hose to caliper bolt washer: 14076180
Rear disk brake mounting plate: 10080876
Rear rotor: 10087702
Rear caliper bleeder cap: 14089150
Rear caliper bleeder: 14081826
Rear caliper piston: 10112643
Rear caliper piston seal: 14067562
Rear brake pads: 10132836
Yup, Just brakes.
Old Feb 27, 2010 | 11:49 PM
Drew's Avatar
Yup, Just brakes.
Mhmm... And just about everything on that list (except the front brakes) was used on other thirdgens.
Old Sep 28, 2012 | 10:29 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Over the winter, I'm going to replace all my bushings and additionally, I may upgrade my front brakes. Although the already upgraded suspension parts are Moog, being somewhat of a purist, I wanted to use some Delco as well.
Based on the above posts, there seems to have been two differing opinions about 1LE parts. Is there, somewhere, a definitive list of truly 'upgraded' parts that the 1LE option provided? Perhaps from an original GM document?
I ask because when I browse EBay and performance sites, I find an abundance of ads claiming "as found on the 1LE optioned Camaro". As an example, the LCA bushing # 10164152 is listed as 1LE on some sites but other sites say it is a standard part.
1988-1992
Fuel tank: 10121026
Fuel Pump: 25116163
Suspension
Brakes
Yup, Just brakes.
Old Sep 28, 2012 | 10:36 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
As Drew states, the 1LE option provided for a larger brakes system for the road courses. Every other part that people state are 1LE specific have been shown to be the same parts used in other Camaros. fuel tank, sender and pump have been found to be used elsewhere. Even GM documentation states that the 1LE came with an upgraded suspension. However, the upgraded suspension was based on what? A base model. The springs, sway bars, bushings, struts, braces, etc are all found on IROC-Zs and later Z28s.
Old Sep 28, 2012 | 10:50 AM
Krik's Avatar
Engine: 5.7 TPI
At a minimum the 1LE gave you the "Best of the Best" of available parts. At best, you got upgraded parts unavailable to the lesser models. If you wanted to race Showroom Stock (and that's really the primary reason this car exists), this car gave you EVERY advantage. You could not put the 1LE parts on another car and still qualify as stock.
There is no substitute.
Old Sep 28, 2012 | 11:48 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Didnt the 1LE cars get a special fuel sending unit that had a swinging pick-up that wasnt available on the base cars?
Old Sep 29, 2012 | 07:20 AM
Krik's Avatar
Engine: 5.7 TPI
Yes. Works like a champ too!
Old Sep 29, 2012 | 02:18 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have never seen a swinging pickup. (I have changed a few 1LE pumps)
It was just a fuel pump strainer/sock that was double sided...
89 TTAs, B4Cs and 1LEs used a "1LE" tank and pickup as did ALL 90ish and up to 92 F-cars.
When looking for a fuel tank, get one from a 91-2 with the plastic baffles and you'll have a "1LE" tank..
Old Sep 29, 2012 | 03:04 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
wait - maybe I am wrong but I thought as well as brakes most were AC delete, Dual Cats and performace axle or N10/G92. Yes availbile on other cars but in the yard AC delete, dual cats might be a place to start to see if it has the big front brakes.
Old Sep 29, 2012 | 03:49 PM
jermdm's Avatar
Car: 1989 Iroc-z
Not to start an arguement but this is from the 89 camaro tech data on the home page.
1LE package was obtained by ordering the following:
Level 1 IROC-Z with 5.0 TPI engine with 5 speed or 5.7 TPI engine Optional axle ratio (G92) (305/3.45, 350/3.27) and its required options.
Air conditioning delete (C41) (standard heater)
Then the 1LE performance package was installed consisting of:
Fog lamp delete Aluminum driveshaft (JG1) Performance exhaust system (N10) (dual catalytic converters) Special deflected disc shocks Aluminum spare wheel with smaller spare tire (N64) Larger (11.86 inch) front rotors with Girlock or PBR Australian built HD front dual piston aluminum calipers Special swinging fuel pickup in gas tank and special 18 gallon baffled fuel tank for fuel pickup down to .5 gallon reserve to prevent fuel starvation in hard cornering.
Some came with special 16x8 light alloy mesh wheels. (XWL)
Dont know if this data pertains to other years.
Old Sep 29, 2012 | 08:15 PM
scottmoyer's Avatar
That information is incorrect and was originally found in print and put up here. No 18 gallon gas tanks have been found either. I have never seen any with "special" rims either. They came with the standard IROC-Z rims.
Old Sep 29, 2012 | 09:14 PM
jermdm's Avatar
Car: 1989 Iroc-z
Thanks for clearing up the info scott. I guess some things arent always true.
Old Oct 5, 2012 | 03:43 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
I am curious is Scottmoyer or someone else very knowledgable might know... Could this 18 Gal rating have come from adding the regular 15.5-16 gal to the coulple of gal reduced from the reserve. If so then the tank is the same just the pickup different resulting in a '18 gal tank'. Is this possible or am I putting to much thought into this.
Old Oct 5, 2012 | 04:48 PM
AmorgetRS's Avatar
My understanding is that due to the baffling some GM media said the the 1LE tank had an extra 15% (or some number like that) fuel "capacity". That was taken as that the 1LE had a bigger gas tank when they it really meant is that because of the baffles the tank had 15% more *usable* capacity because it didn't end up starving for fuel.
I couldn't find the thread on that, but it makes sense.
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
