What does the "M5" mean?
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Car: 1992 Firebird
Engine: 305 TBI
Re: What does the "M5" mean?
I might be wrong (Sr. member correct me if so) and it sounds crazy, but I am pretty sure MM5 is the RPO for an automatic. Check the RPO decoder to be sure.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
As mentioned before, Typically speaking M5 would indicate the Manual 5 speed (Borg & Warner) Transmission, the A4 would indicate the Automatic 4 speed (IE the 700R4/4L60).
The 200R4 was used in the 1989 TTA, so A4 could be used as a reference for those as well
Other transmissions used on third Gens would include the A3 (Automatic 3 speed, IE TH350 Trans) which was more or less a 1982 only thing, they did use the A3 when paired to the 4 cyl engine in 1982 - 1985 IIRC. The same goes for the M4, which is a Muncie Manual 4 Speed Manual trans, again it was used primarily in 1982, and then the I4 got it from 1982-1985 IIRC..
The M6 was only used in 1991 and 1992 on the Firehawks, this was the Manual 6 speed.
AFAIK, that is all the transmissions used in third gens... Hope it helps.
Car: '95 Impala SS
Engine: 350/LT1
Transmission: (Sold my '89 Formula 350)
Other transmissions used on third Gens would include the A3 (Automatic 3 speed, IE TH350 Trans) which was more or less a 1982 only thing, they did use the A3 when paired to the 4 cyl engine in 1982 - 1985 IIRC. ....AFAIK, that is all the transmissions used in third gens... Hope it helps.
I have some corrections...
The Manual 4 speed in 1982 was the Saginaw (not a muncie)
and the Manual 4 from 1983 thru 1986 was the Borg & Warner.
And you are correct, I always thought it was the 350, but indeed it was the THM200C, which should not be confused wtih the THM200-R4 which was used in the Buick Gran Nationals until 1987 and the TTA in 1989...
The 200 was probably better suited for the V6 and I4...
Thanks for the correction and making me look it up...
