Vin Check
Old Apr 21, 2010 | 10:56 PM
johnnymotz27's Avatar
Car: '89 L98 G92 Iroc /'11 GS Vett
Engine: L98/LS3
Transmission: 700R4/M6
Axle/Gears: 3.27 B.W./3.42
Vin Check
Thinking this camaro is a standard 89 Iroc but if someone had the time and had a way to run a vin could you let me know???
1G1FP2188KL207185
Old Apr 22, 2010 | 12:16 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: Vin Check
1G1FP2188KL207185
Hello johnnymotz27!!
Well the VIN confirms a 1989 Chevrolet Camaro F Body with a 5.7L engine, but the VIN won't tell you if it's an IROC or not!!
You need the RPO codes off of the SPID in the center console!!
B2L, L98, and Z28 = IROC
Old Apr 22, 2010 | 12:21 AM
Engine: L98/LS3
Re: Vin Check
Well a 5.7 in Vin would confirm Iroc....No? And that would be the 8 in the vin correct?
Old Apr 22, 2010 | 02:20 AM
Re: Vin Check
Using that thinking then, any 1987, 1988, 1989, 1990 ( manufactured up unitl Dec 31 1989) Camaro with the engine code "8" in the VIN is an IROC, since the IROC is the only Camaro that came with the 5.7 in those years!!
However, the VIN doesn't tell you that it's an IROC specifically, based on the way your question was asked!!
Old Apr 22, 2010 | 02:23 AM
Engine: L98/LS3
Re: Vin Check
Agreed , sorry if i wasnt very clear i was hoping someone was able to pull all the RPO codes from the vin. Thanks for your help though!
Old Apr 22, 2010 | 02:43 AM
Re: Vin Check
Hello johnnnymotz27!!
GM can pull the RPO codes from the VIN, or somebody on these boards that happens to have access to a dealer's data base!!
Try www.compnine.com they have a VIN decoder on the left hand side of their main page under resources, I just tried it again, and it's pretty good!!
P.S. I just tried to run your VIN through it, and got a nothing found!! Check out the site anyways, and check your VIN out for yourself!!
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
