Apparently I have a "rare" 1991 Z28
Car: BMW 330i ///M Sport
Engine: M54 DOHC I6
Transmission: 5 speed
Axle/Gears: Stock
I looked at the RPO codes on my newly purchased 1991 Z28. I was surprised at some of the original options, as some of these things are no longer in the car. It's a bright red hardtop 305 A4 car, but it had the power seat with the cloth interior. I though hardtop cars were pretty "Plain Jane" when it came to options, it was always the T-Top cars that got the special treatment. It has a ton of options for a hardtop. I looked the car up on Compnine, all the RPO's listed are correct, the car comes back 1 of 1 built. I know having weird options doesn't exactly make it desirable but I'm very interested now!
I can get a pic of the RPO sticker tomorrow, I have the VIN # now though, can anybody tell me anything about this car?
1G1FP23F2ML132286
RPO's all came up correct, this is the list:
CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH BERETTA GT PKG Z21) GA(UB3)
CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH DELUXE SPORT PKG W32) GA(UB3)
89,578UN6RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UN6)
RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK(EXPORT) STEREO CASSETTE(UN6)
77,719UQ1RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1)
88,820U79SPEAKER SYSTEM,4,DUAL FRONT COAX,DUAL EXTENDED RANGE PACKAGE SHELF 4 SPKR SYS(U79)
82,582VANPLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN)
89,578VK3LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
81,034V73VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
88,169Z28PERFORMANCE PACKAGE,SPECIAL PERF PKG(Z28)
SPECIAL PERFORMANCE PACKAGE,(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(Z28)
12,1541AZUnk.8,2451SDPACKAGE-OPTION 04 (1SD)
6,6366XTCOMPONENT FRT LH COMPUTER SEL SUP (6XT) SUSP(6XT)
5,1447XTCOMPONENT FRT RH COMPUTER SEL SUP (7XT) SUSP(7XT)
5,1448NLSPRING-COMPTR SELECT RR LH SUSP(8NL)
43,06081PWHEEL COLOR,BRIGHT RED (81P)
15,09881QMOLDING COLOR - BRIGHT RED (81Q)
15,58981UEXTERIOR COLOR,PRIMARY (81U)
EXTERIOR COLOR,PRIMARY,BRIGHT RED (81U)
16,57882CTRIM COMBINATION,CLOTH,MEDIUM DARK GRAY (82C)
28,19082IINTERIOR TRIM,MEDIUM DARK GRAY (82I)
52,890829SEAT BELT COLOR - MED DK GRAY (829)
52,8909NLSPRING-COMPTR SELECT RR RH SUSP(9NL)
43,060AC3ADJUSTER,SEAT,6-WAY POWER,BUCKET,DRIVER 6-WAY PWR D/SEAT ADJR(AC3)
8,281AJ3RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3)
89,578AM9SEAT,REAR,FOLDING SPLIT BACK FLDG SPLIT BK R/SEAT(AM9)
SEAT,REAR,FOLDING SPLIT BACK(USED WITH BERETTA GT PKG Z21) FLDG SPLIT BK R/SEAT(AM9)
52,357AR9SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
89,578AU3LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
56,960A31WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
55,374A90LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90)
64,379B18ORNAMENTATION,INTERIOR(DELUXE) DELUXE INTR(B18)
ORNAMENTATION,INTERIOR(DELUXE)(USED WITH BIARRITZ YP3) DELUXE INTR(B18)
ORNAMENTATION,INTERIOR(DELUXE)(USED WITH D'ELEGANCE V4S) DELUXE INTR(B18)
ORNAMENTATION,INTERIOR(DELUXE)(USED WITH LE Y91) DELUXE INTR(B18)
ORNAMENTATION,INTERIOR(DELUXE)(USED WITH SE Y92) DELUXE INTR(B18)
ORNAMENTATION,INTERIOR(DELUXE)(USED WITH SSE Y85) DELUXE INTR(B18)
ORNAMENTATION,INTERIOR(DELUXE)(USED WITH TROFEO SPORT COUPE WL3) DELUXE INTR(B18)
52,357B34COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34)
83,850B35COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
83,850B84BLACK BODY SIDE MOLDING BODY SI MLDG(B84)
ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH APPEARANCE PACKAGE Z12) BODY SI MLDG(B84)
ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH STE Z7N) BODY SI MLDG(B84)
84,227C49DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
55,564C60AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
86,405DC4MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4)
55,414DG7MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC(PAINTED)(USED WITH SE Z7M,STE Z7N,LE Z7K) O/S ELEC R/CON PAINTED MIR(DG7)
20,287D3WGEAR-SPEEDO DRIVEN (25513044) (D3W)
38,553D34MIRROR,INSIDE,SUNSHADE S/S MIR(D34)
MIRROR,INSIDE,SUNSHADE(USED WITH BERETTA GT PKG Z21) S/S MIR(D34)
12,154D42COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42)
55,813D8NSENSOR VEH SPD (10456088) (D8N)
55,794D81SPOILER,REAR,AERO WING RR AERO WING SPLR(D81)
12,154E5ZUnk.89,578E9ZUnk.89,578F41SUSPENSION,FIRM RIDE HANDLING,FRONT AND REAR FIRM RIDE & HANDLING SUSP(F41)
SUSPENSION,FIRM RIDE HANDLING,FRONT AND REAR(USED W/TOURING PKG WF1) FIRM RIDE & HANDLING SUSP(F41)
35,510GU2AXLE,REAR,2.73 RATIO 2.73R(GU2)
40,622G80AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
12,751IPCTRIM,INTERIOR DESIGN (IPC)
48,156J41BRAKE SYSTEM,POWER,FRONT DISC,REAR DRUM(CAST IRON) CAST IRON FRT DISC/RR DRUM BRK SYS(J41)
84,061K34CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
55,334K68GENERATOR,105 AMPERE 105 AMP(K68)
12,557LB9ENGINE,5.0L(5.0F),V8 EFI CAR ONLY 5.0F(LB9)
6,601MD8TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8)
75,616MX0TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)(MD8) A/TRANS PROVISIONS(MX0)
75,616NA5EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
78,845NP5STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
STEERING WHEEL,LEATHER WRAPPED(USED WITH GTZ Z04) LEATHER WRAPPED STRG WHL(NP5)
STEERING WHEEL,LEATHER WRAPPED(USED WITH LE Z7K) LEATHER WRAPPED STRG WHL(NP5)
STEERING WHEEL,LEATHER WRAPPED(USED WITH SL Z7R,INTERNATIONAL Z7Q) LEATHER WRAPPED STRG WHL(NP5)
STEERING WHEEL,SPORT,3-SPOKE,LEATHER WRAPPED(USED WITH PERFORMANCE PACKAGE Y56,SPORT PACKAGE WN2) LEATHER WRAPPED STRG WHL(NP5)
12,389N65WHEEL AND TIRE,SPACE SAVER SPARE(STEEL) STOWAWAY SPARE(STEEL)(N65)
WHEEL AND TIRE,SPACE SAVER SPARE,STEEL STEEL SPACE SAVER SPA(N65)
7,822N96WHEEL,16X8(CAST ALUMINUM) AL WHL(N96)
44,795QMTTIRE ALL P235/55R16/N BL R/PE ST TL AL2 TIRE(QMT)
35,510R8TUnk.44,926T96LAMP,FRONT FOG FRT FOG LP(T96)
LAMP,FRONT FOG(EXPORT) FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH APPEARANCE PACKAGE WS4) FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH BERETTA GTZ Z04) FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH DELUXE SPORT PKG W32) FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH INTERNATIONAL Z7Q) FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH Z28) FRT FOG LP(T96)
1G1FP23F2ML132286
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Re: Apparently I have a "rare" 1991 Z28
I've seen lots of loaded hardtop cars...not everyone wanted t-tops back then. One thing I like about my 86 is that its a hardtop...compared to the RS and IROC, its super quiet and tight. If it was my only third gen, I'd rather have a t-top car, but that's another story.
My 86 has a power seat as well. What's odd about mine is that the WS6 package in '86, for $665, added rear discs, posi, 245/50/16 tires on 16" wheels and the stiffer bars. My car has the posi ($100), rear discs ($180), and larger 235/60/15 tires ($180), for a total of close to $500. On a car that stickered for over $17,000 24 years ago, I hae no idea why they bothered to save less than $200 and not just get a WS6!
My best guess? The first owner was female, and maybe she wanted a better riding car. Maybe there was a restriction on WS6 when this one was ordered. Whatever it was, its definitely unique and while it doesn't corner like my IROC, it does handle well and the ride is vastly better.
I didn't even realize it had upsized tires until I got it home...I read the door, and found they were original.
Compnine's website says every car is rare. It's like saying that a squirrel is a rare 1 of 1 because it's the only one living in the tree in your front yard. It's a real 'feel good' website, but it's not very accurate. Even if you compare production numbers for options they don't usually match. For example, sometimes they'll have a production number for an option that was only available as part of an option package, but then the number for the package is off (usually by several THOUSAND units) from the single option. Don't put too much faith into it. The invoice date, and the RPO codes are usually correct for the car, the definitions, and the numbers, are sometimes correct, and the "Rarity" section is complete nonsense. It's nonsense that's derived from a database, and carefully calculated by an algorithm of some sort, but truly useless since it cares about details that no human would give a second thought.
I don't see anything truly unusual browsing through your RPO codes. The options I'd like to see, that indicate performance parts, are missing. The 91-92 Z28's suffer the same issue as 88-90 Irocs. Starting in 88, GM dumbed down the flagship of the line to sell more cars. In 87 an Iroc was the top of the line car, the Z28 was a step down, and then the LT, and Sport Coupe at the bottom. For 88, it was either Sport Coupe, or Iroc. They still made several different levels of car, but on the outside they're the same thing. It changed a little in the following years, 89 it was RS or Iroc, then in 91 it was RS or Z28. The way it worked out, the step from the top of the line RS to the entry level Z28 changed only a handful of parts, the Z28 got the 305TPI, fog lights, hood blisters, the tall spoiler, badges, and the leather steering wheel/shifter/ebrake handle. Everything else was the same as the next step down RS. Of course the top of the line Z28 in 91 added the FE2 suspension (think Iroc/WS6), 245/50ZR16 tires, and the performance options like the oil cooler, 3.23 or 3.42 gears, aluminum spare, dual cats, rear discs, and so on.
Those Z28's with the performance options are generally the ones that are sought after, and would be considered rare. It could be that the production number for F41 Z28's is smaller then FE2 Z28's, making the less desirable car technically more rare, but it doesn't change the fact that most people given the choice would choose the car with more performance.
Car: 1988 Camaro RS
Engine: 355
Transmission: TH-350
Axle/Gears: 4:10
I left the 88 RS out for simplicity, but the RS is basically the same as the 88 Sport Coupe, the biggest difference was the RS had body colored ground effects, while the SC had silver or gold like the earlier Z28.
This. It seems they come up with their percentages based off of combinations as well. My car, as an example, comes up as 1 of 1, if I add a power rear hatch, the number goes up to a couple hundred (obviously it was an option most people took advantage of with Formulas). Breaking things down to that small a detail makes every car almost a 1 of 1.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yeah, compnine is a good resource, but the way the break everything down, it makes every car "rare" but as you all know, or should know, "rare" does not mean desirable or valuable.
FWIW, my 92 v6 bird is 1 of 2 on compnine.....
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
Buggy Disaster
Sep 22, 2015 01:15 PM
