89 iroc
Old Oct 2, 2011 | 03:36 PM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
89 iroc
i no my car isnt rare but i was wondering if anyone could tell me how many silver 1989 irocs were built with a red interior and 305 tpi automatic
Old Oct 2, 2011 | 04:15 PM
mr396's Avatar
Car: 2003 BMW E46 M3 Vert
Engine: 3.2 I6 M power 333 h.p.
Transmission: SMG 6 speed
Axle/Gears: 3.62 posi
Re: 89 iroc
There were 8,925 TPI's made in 1989. I don't show silver as a factory color in 1989.
Old Oct 2, 2011 | 04:29 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: 89 iroc
In 1989? Zero.
Old Oct 2, 2011 | 04:47 PM
Car: 89 iroc
Engine: 355tpi
Re: 89 iroc
well it dosnt look to b painted but how can i tell what the factory color is cause the sticker inside the door is faded
Old Oct 2, 2011 | 04:53 PM
chazman's Avatar
Axle/Gears: BW 3.45
Re: 89 iroc
Post some pics. The RPO sticker inside the console door will have a paint code.
If it's silver, it's either not a 1989 IROC or it has been painted.
Old Oct 2, 2011 | 10:45 PM
Slater126's Avatar
Re: 89 iroc
By GM, 0. By backyard rebuilders, probably quite a few. Unless they did a super job, it should be easy to tell what the original color was. Look inside the door jambs and under the hood. I'll bet you'll see it once you start looking.
Old Oct 3, 2011 | 07:28 AM
Car: 89 iroc
Engine: 355tpi
Re: 89 iroc
ill look at the codes when i go out later but the car looks to b 100 percent silver from factory i mean door jams underhood and everything r silver even the door stickers r still there with silver under them
Old Oct 4, 2011 | 08:59 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: 89 iroc
Then the car's an 85, not an 89.
Where's the IROC-Z logo on the door, front or rear?
Do the rims have an indented line in each spoke or multiple?
Is there a 3rd brake light? where?
Door moldings? squared off and narrow or wide and rounded with bullet shaped ends?
Old Oct 4, 2011 | 09:32 AM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
Re: 89 iroc
If the paint looks stock, Most likely someone "Iroc-ized" a RS...... Snap some pictures.
Old Oct 4, 2011 | 03:31 PM
Car: 89 iroc
Engine: 355tpi
Re: 89 iroc
the car is a iroc it has the vin code f for the 305 tpi it has the code k for a 89 it has the black iroc logo on the bottom back of the doors the third brake light is on the small spoiler and the side moldings r rounded and r pointed on the ends ad the wheels r 15 in with iroc center caps and two groves and the center is diped in not flat like the rs wheels... if someone can tell me how to post the picks ill put some up
Old Oct 4, 2011 | 10:30 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 89 iroc
photobucket -> upload pictures from hard drive.
then enter the link straight into the post.
Old Oct 4, 2011 | 11:56 PM
johnnymotz27's Avatar
Car: '89 L98 G92 Iroc /'11 GS Vett
Engine: L98/LS3
Transmission: 700R4/M6
Axle/Gears: 3.27 B.W./3.42
Re: 89 iroc
Are you sure the car isnt Gray?????
Edit: Sorry only RS came in Gray
Old Oct 5, 2011 | 12:41 PM
Car: 89 iroc
Engine: 355tpi
Re: 89 iroc
Old Oct 5, 2011 | 05:57 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: 89 iroc
Its been repainted or someone is trying to make it LOOK like an IROC. Your IROC logo is too low on the door and where are the stripes that normally go just above the ground effects?
Old Oct 5, 2011 | 09:12 PM
Car: 89 iroc
Engine: 355tpi
Re: 89 iroc
well tell me y it has the vin for it being a tpi o yea thats rite cause its a iroc
Old Oct 5, 2011 | 09:44 PM
scottmoyer's Avatar
Re: 89 iroc
The car has been repainted. That color was not available in 89. The rims are correct for an 89 and the VIN K also proves that. The fact the decals are too low and are black without stripes tell me that the car was probably painted. There was an option for stripe delete in 89, however, I doubt your car has that option. If you can't find any other color on the car, then the body shop did a complete repaint and hopefully did a good job. You can open the right side rear panel and see if there is any color in there with the spare tire. I think there is factory color in there.
Old Oct 5, 2011 | 10:47 PM
Drew's Avatar
Re: 89 iroc
Of course it's a repaint... Notice how the hardware in this picture is painted?
Old Oct 5, 2011 | 11:47 PM
Car: 89 iroc
Engine: 355tpi
Re: 89 iroc
even if the hardware is painted how did the stickers get back on and since from gm u coulda ordered the car however u wanted dont u think some one could have ordered a silver car
Old Oct 5, 2011 | 11:57 PM
Impaqt's Avatar
Re: 89 iroc
Peel the sticker. your factory color is underneeth. They masked off the stickers, but not the door bolts.
you cant order something thats not on the option sheet.
Old Oct 6, 2011 | 06:33 AM
Drew's Avatar
Re: 89 iroc
I don't know, I wasn't there when your car was repainted. Either they masked the decals before spraying paint, or they removed them and reapplied them. Either way, the factory didn't paint some of the parts visible in your pictures body color.
And no you couldn't order a car however you wanted. Go try to order a 2012 Camaro in hot pink with purple polka dots and let us know how that works out for you.
You asked a question, and you got answers. It's too bad you don't like the replies you've gotten, but it's starting to get more then a little silly that you're unwilling to accept what you're being told.
Old Oct 6, 2011 | 08:35 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: 89 iroc
In that first pic I see 91-92 Z28 wheels.
Old Oct 6, 2011 | 12:03 PM
Car: 89 iroc
Engine: 355tpi
Re: 89 iroc
yea the wheels on the car now r off of my 92 rs and i would b willing to accept the fact if it wasnt so convincing that the car came silver and good comment about the camaro in hot pink.
Old Oct 6, 2011 | 12:33 PM
Drew's Avatar
Re: 89 iroc
Convincing? You're claiming you have something that all the printed materials say doesn't exist. You've received expert opinions that it doesn't exist. You've posted pictures which we've explained show that the car has been repainted.
You stated that you "coulda ordered the car however u wanted" when clearly that wasn't the case then, and isn't the case now. You are the only one who's convinced the car was originally silver.
Old Oct 6, 2011 | 01:58 PM
yo soy el warg's Avatar
Re: 89 iroc
How about a picture of the SPID so we can see the RPO codes. That will put an end to it! No picture= No IROC, pretty simple. Picture with correct codes= extremely rare car. You know what I would bet on.
Old Oct 6, 2011 | 02:23 PM
Impaqt's Avatar
Re: 89 iroc
How bout we just let the guy believe that someone accidentally put the wrong paint in the sprayer at the factory and then put all the stickers on wrong and just said... "Screw it, Send it out!".
Old Oct 6, 2011 | 03:38 PM
scottmoyer's Avatar
Re: 89 iroc
I don't like public reprimands, but I will make it here. DO NOT BYPASS THE LANGUAGE FILTER! It's in the board policy that you accepted when joining TGO. Using special characters to represent letters is blatant bypassing and will not be tolerated.
Camaroboy, you asked for help regarding how many silver 89 IROC-Zs were built and the question was answered. There were none. Your car is a repaint. Accept it.
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
mustangman65_79
Aug 23, 2015 02:00 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
