formula...Trans Am or firebird?
Car: 1991 Bird
Engine: Goodwrench 4bolt 357 bore vortec
Axle/Gears: 10 bolt posi disc w/3.23
okay so i was just wondering what views, facts, or opinions you gurus have on the formula. Okay heres the deal....a car show with 2 classes, a trans am class and a firebird class. what class should the formula be in? hope i am in the right place for this question
Transmission: Pro-built 700R4
Re: formula...Trans Am or firebird?
Its a Firebird, as designated by the "S" in the VIN, so it should be in the Firebird class. If the letter for body style was a "W", then it would be in the T/A class.
Car: 1991 Bird
well that would make sense, but i know the firebirds come standard with a V6 and a formula come standard with a V8. not to mention the WS6 package on the formula. is the formula not a T/A minus a ground efx kit?
Vin says Firebird, that is what matters. According to that it is a Firebird w/ the option of a TPI motor, WS6, power bulge hood and a aero wing. The vin would be W if it was a Trans Am less ground effects.
Car: 1991 Bird
i understand what the VIN states, is that not due to GM starting with a base model to build a car that would run down the T/A. after all, i have not seen a factory firebird with a power bulge hood. and i am saying as far as a car show goes....where would the formula be best placed. up against birds, or T/As?
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I see them as all Firebirds.... Base model Firebird, upgraded models are the Formula and Trans Am, both still Firebirds, just more fancy than base model...
Despite the VIN, They are all firebirds in essence...
Car: 1991 Bird
okay...so you have a v6 base model bird up against a formula with all the bells and whistles of a T/A.... or lets up the ante to a V8 base model bird....it should be "special edition" birds in the same class and base models in their own class.
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
I've seen base 3.1's with more options (bells and whistles) than some Formulas have. Plus Formulas never came with gfx, but it was an option on the base model.
Car: 1991 Bird
Car: 1991 Bird
true, however the reason the formula was with out ground ef was to save weight so with the same engine as the T/A the formula would have better performance #S then the T/As. and what about the wing....that was not available on the base birds. as far as options, 91-92 only base birds and T/As had ground efx.
Car: 87 GTA
Firebird=Formula Model Firebird=Trans Am model Firebird
Like saying a Z28 isn't a Camaro , to me.
Car: 1991 Bird
i like that stephen. i like that alot. they should not class cars like that. they should stick between show car and daily drivers! i am liking the input i have gotten here. i am just gonna build my bird to show car quality and drive it like i do now!!
If you're going to show your daily driver you should expect some one will show up with a car that's never driven and clean your clock with half the effort. It's a full time job keeping a daily driver in show condition. I'm not going to say it's impossible, but it's a whole lot easier to have a dedicated show car that sits in a storage unit under a cover. Come show day, you pull off the cover, unplug the battery tender and drive to the show in a perfectly detailed car. It's a beauty contest, you're not usually awarded for hard work. Some doctor with more money then brains will probably beat you with his trophy car that he hasn't ever so much as turned a screwdriver on, much less a wrench.
Takes BIG bucks to keep a car in pristine condition.
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Pretty much, the Formula was an option on the base Firebird, the Trans Am was considered it's own carline therefore the Forumla would be in the same class as the base model firebird.
The GTA would fall in the Trans Am line because it was an option for the T/A as well.
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
I agree with Drew...its pretty much impossible to keep a daily driven car pristine. I've driven my IROC less than 400 miles since I purchased it in June...it was showroom clean when I bought it. Despite this, I'm always washing it (dust still gets under covers...dusting the inside...wiping down all the door jambs...
I drive it to a cruise night once a week on Wed night...so my Tues ritual is cleaning this thing. I can't imagine if I drove it every day how much extra work I'd have!
Car: 1991 Bird
keeping your ride clean is part of the bonding experience! i do under stand, but points wise i was only 5 off from the others score. though he won the award i won much respect due to my picture book of me and my friends all working on the car. top to bottom my hands and tools were there. so despite my 230kmile bird, it was undeniably worthy of being amongst show cars!!
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
i had shown my car and its a daily driver, they had the formula in a different class until it was time for judgment then they put his SHOW car in my class. unfortunately they do not go by show/ daily driver and just by years and models. i was just stoked by the way they had him under T/A class then it was Firebird
Here we go again....Travis, I'm sorry that you feel cheated in the results from last weekends show but Don and whoever else filled out the paperwork had my car classed as a Firebird for the entire show, at no time was it ever listed with the Trans Ams. There was only 1 dash info page handed out to each car and mine was the same class as yours from start to finish. Yes, Formulas are considered Firebirds just like GTAs are considered Trans Ams due to the VIN numbers which from what I gather is how they seperated them. And you do earn a lot of repect from people, especially me in being able to maintain the car in excellent condition for a daily driver...you've been working on yours for how long,5 maybe 6 years since you bought it? I drove mine daily for 12 years and have been working on and trying to maintain it like you ever since day one (20 years ago). This was one of the good things that happened while we were in CFB, the seperation of show and drivers in the judging which was an idea I suggested back then in an effort to prevent this exact type of thing from happening. It worked for the most part but this is a different group,different rules,etc. I would suggest that before bringing this up here it would have been better to speak with Don or bring it up in the club's meeting this weekend and seek some form of resolution there. Now don't take any of this the wrong way, I consider you a friend and have no wish to start a conflict with you. This just fired me up bringing up bad memories from past judgings in CFB.
Stephen,
I get your point about the difference between a Firebird and T/A & Camaro and Z28 (and it is a valid rebutal), but do any of the different Camaros have a separate VIN code as the 'Birds and T/As do?
-Eldon
Cool. Talk about differences between models, I tried to upgrade my shifter with a BW aftermarket shifter, it's only made to fit the TA's. Nothing available for a Formula. Go figure! Hope you two can iron out the rift. I would PM him...
Car: 1991 Bird
Car: 92 Camaro RS
Engine: 350 ci Carb
Transmission: 5speed
First of All... here we go again...
Aren't they dead? yes.. they are
Rigged votings, weird rules, **** talking, you did it to yourselves. talk to anyone who knows CFB and they will tell you the same thing.
Judgings that were rigged. It's pretty noticeable when the corvette club does NOT EVEN LOOK AT THE CAR.. Just the # on the sheet, and a quick glance. yea i'm sure they saw alot in a whole 5 f**ing seconds. jack-asses... i was NO born yesterday mike. sorry, you guys couldn't fool me or any of the people i know in the club.
Some people fail to realize that their car that sits in a garage 364 days out of a year, sees maybe 1 weekend drive every year is MUCH different from the car thats gets driven EVERY DAY... the latter being the daily driver.
I usually say to this person who thinks their show car is soooo much nicer .. "hey, good for you. you spent thousands fo dollars in paint and interior restoration and everything else... now it sits in a garage or under a cover for 99% of the year. wow you're special.. not. I drive my car every day. you know why? THATS WHAT IT IS MEANT TO DO!!!!! Drive your car, or stop talking **** ;-)"
Rigged votings, weird rules, **** talking, you did it to yourselves. talk to anyone who knows CFB and they will tell you the same thing.Here we go again....Travis, I'm sorry that you feel cheated in the results from last weekends show but Don and whoever else filled out the paperwork had my car classed as a Firebird for the entire show, at no time was it ever listed with the Trans Ams. There was only 1 dash info page handed out to each car and mine was the same class as yours from start to finish. Yes, Formulas are considered Firebirds just like GTAs are considered Trans Ams due to the VIN numbers which from what I gather is how they seperated them. And you do earn a lot of repect from people, especially me in being able to maintain the car in excellent condition for a daily driver...you've been working on yours for how long,5 maybe 6 years since you bought it? I drove mine daily for 12 years and have been working on and trying to maintain it like you ever since day one (20 years ago). This was one of the good things that happened while we were in CFB, the seperation of show and drivers in the judging which was an idea I suggested back then in an effort to prevent this exact type of thing from happening. It worked for the most part but this is a different group,different rules,etc. I would suggest that before bringing this up here it would have been better to speak with Don or bring it up in the club's meeting this weekend and seek some form of resolution there. Now don't take any of this the wrong way, I consider you a friend and have no wish to start a conflict with you. This just fired me up bringing up bad memories from past judgings in CFB.
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
