Need a new shifter boot (rubber preferred)
Old Aug 31, 2010 | 12:43 PM
Wiggles's Avatar
Car: 84 Firebird, 78 Trans Am
Engine: LG4 305 Qjet, Pontiac 400cid
Transmission: T5 Non WC, TH350
Axle/Gears: All stock
I need a new shifter boot since the old one can allow debris to fall down below into the gear box and the heat that's entering is ridiculous.
If possible, I want a rubber accordion type of boot and not leather or vinyl. I know the dimensions are 4" x 6" (10cm x 15cm) and noticed that some replacements come with a plate already which wouldn't work with the console and those cheapo plastic torx screws. I wanted to check here first to see if anyone else knows of the proper part number/manufacturer that will work.
Old Aug 31, 2010 | 03:26 PM
Drew's Avatar
Re: Need a new shifter boot (rubber preferred)
The correct original part is long since discontinued. You might try a 4th gen boot, assuming you can find one. Chances are good they're discontinued too.
Old Aug 31, 2010 | 03:34 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sounds like you're missing the lower boot as well.
JamesC
Old Aug 31, 2010 | 04:37 PM
Wiggles's Avatar
JamesC
I wasn't even aware a lower shift boot existed. I've always thought the boot (on any manual transmission) is always visible and mounted on the console or floor. I will have to remove that cheap plastic plate and have a look down there.
Old Aug 31, 2010 | 04:49 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Nope; There are two; the "lower shifter boot" which mounts to the trans tunnel and the upper/console shift boot which is more for aesthetics. The lower boot is the really important one as it is designed to keep debris, noise, gases, and heat out of the cabin where the shifter comes through.
Abubaca suggested using a rain/pipe boot from Lowes:
http://www.lowes.com/pd_53196-138-14052_4294934210_4294937087?productId=3127041&Ns=p_product_price|1&pl=1&currentURL=/pl_Flashings_4294934210_4294937087_?rpp=30$No=90$Ns=p_product_price|1
After reading his suggestion with what he did, I took a look at it at Lowe's; The boot is almost exactly the right size and looks like it should work great; I plan on using it when I do my T5 swap here in the next couple weeks. I've searched really hard for a 3rd or 4thgen one and they seem to be either nonexistent or badly used.
Old Sep 1, 2010 | 04:23 PM
Wiggles's Avatar
That idea is so good that I went down to Lowe's during my lunch and picked one up. Now, all I need to do is remove the console plate and the top boot and see what surprises I find down there prior to installing.
Thanks a bunch for the Lowe's link (you too Abubaca)
Old Sep 1, 2010 | 05:45 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Let us know if dimensionally, its the same/similar... I will be using it on mine but since I can cut as small a hole as I need, I know it will work w/o issues. I've never heard of it being used to replace a factory cut shifter hole, so it'll be valued information to know if it fits over the stock cut hole.
Let us know!
Old Sep 1, 2010 | 07:03 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Hey, I've got a couple of GM oem lower shift boots off of 91 and 92 Camaros with t-5 trans in fine shape if anyone wants one of those.
Old Sep 4, 2010 | 04:06 PM
buffaloman's Avatar
Car: 1989 Firebird Fornula 350
Engine: 350 L98 / NOS
Transmission: 4sp Auto
This is what you need.
Attached Thumbnails Need a new shifter boot (rubber preferred)-331531481_tp.jpg
Old Sep 6, 2010 | 10:44 PM
Wiggles's Avatar
Alright, so over the weekend, I removed the upper boot, and had a look inside. Apparently, the lower shift boot is in pretty good shape except for a small minor rip. Impressive for something about 26 years old.
Despite this, I placed the roof flash piece over top of the console for perspective purposes. It obviously was too big to fit inside, but it looks like if one were to carefully cut the proper dimensions, the roof flash will work for a lower shift boot replacement.
Old Sep 7, 2010 | 05:34 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Yeah, in order to get the old boot out, you really have to take the console out to get at the side bolts. It looks like the new 'boot' will work, just need to remove the console and center it up in there. It'll be tight inside the console, but not so bad that I think it'll cause any issues at all.
When you have it all apart, you'll have to let us know if that roofing boot will fit over the stock cutout in the trans tunnel.
PurelyPMD
May 5, 2016 04:57 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
MarineIROC
Southern California Area
Sep 16, 2015 05:40 PM
BOOT77
Sep 5, 2015 03:55 PM
