Where to find the Engine vin?
Old Sep 25, 2010 | 08:48 AM
chevypower91's Avatar
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
Hi there,
I was wondering if someone would be able tell me where on the engine block I can find the partial vin stamping. Please also include a pic on the location. The car is a '91 Z28.
Thanks for your assistance in advance.
Old Sep 25, 2010 | 08:50 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Where to find the Engine vin?
On the deck surface in front of the passenger side head.
Old Sep 28, 2010 | 09:00 AM
Engine: 305 cid
Hi Apeiron,
Thanks for the reply. Do you have a pic on where on the deck surface I would find it, as the ac compressor is in front of the head.
Old Sep 28, 2010 | 10:35 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Originally Posted by chevypower91
Hi Apeiron,
Grab a flashlight.
test the flashlights batteries by turning the switch on and off once or twice.
open driver door
pull hood cable inside car down by drivers feet (kick panel).
close driver door
release the secondary hood latch front and center of hood bottom while
opening hood
move to pass side fender
turn on flashlight again
Point eyes and light around behind your A/C compressor. Its maybe 1 1/2" x 1" pad that sticks out past the cyl head.
It may have oil and grease covering it so you may need to clean it off with a scraper or rag.
Old Sep 28, 2010 | 11:44 AM
Drew's Avatar
You might try a search...
This thread comes up without looking too hard.
https://www.thirdgen.org/forums/hist...h-numbers.html
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
