Need CENTERCAPS for Iroc wheels...pic inside, thanks!
I need some center caps for these wheels...I don't mind if they do not say IROC or Camaro on them, just plain jane black center caps for THESE wheels...:
Let me know if you have any or can tell me where to find some, many thanks!!!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Need CENTERCAPS for Iroc wheels...pic inside, thanks!
Hey, Steve,
Posting in one forum is the best best. Check your post in the classifieds for info on your request.
JamesC
JamesC
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
thats an rs wheel jus like mine heres your link :
http://cgi.ebay.com/ebaymotors/82-92...Q5fAccessories
They used those wheels all the way from 82-92 on the base model Sport Coupe, RS, Z28, and Iroc.
Most of the cheap knock off Ebay caps don't have the spring steel clip inserts. Instead they just have the plastic pins and clips. If you want the caps to stay on the wheels and be the same quality as OEM, look for either used, NOS, or GM restoration parts. The cheap caps WORK, they just expect a lot from molded plastic.
Engine: l98 tpi
Axle/Gears: 2.77
i've had mine about 6 months with no problems . i was worried when i ordered them but they seem to be fine .
I sold the set of those wheels I'd had since 1996 last summer. My buddy wanted black caps and different emblems, so he got a set of the generic caps off Ebay. They didn't want to fit without breaking. I had to get aggressive with them to make them snap into the wheel. I doubt they'll last many cycles of being removed and snapped back in. The plastic tabs just aren't flexible enough.
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
little correction from what drew said. the base model wheel that used these caps were only in the years hat the base model wheel was a 15" wheel. the 14" caps from the earlier years were different
Worse yet there are three different 82-87 Sport Coupe caps. 82-84 have the clips on the wheels, 85-87 have the clips on the caps which snap into the lug nuts, and they were offered in both black and gray. Lots of variations to keep track of.
Iroc8t8
May 4, 2026 08:09 PM
mustangman65_79
Aug 11, 2015 03:17 PM
