85 trans am
Old May 6, 2011 | 08:47 PM
davidj3594's Avatar
85 trans am
hi can anybody tell me if there is anything special about this 85 trans am?
here are the rpos
aaa ak1 am9 ar9 au3 a01 a31 a90 b20 b34 b35 b48 b67 b97 cc1
cd4 c49 c60 dg7 dk6 dx1 d03 d27 d42 d6f d80 d88 e5z e7z f41
gw6 g80 j65 k34 k90 lb9 md8 mxo na5 np5 n33 n65 n90 Qac tr9
t93 t96 ua1 uQ7 ut1 ut4 u21 u23 u25 u27 u29 van vk3 v73 ws3
ws4 ws8 wu1 ww5 w62 yr1 ys1 yt1 yt9 y99 62x 60p 68c 681 689
69l 69u 7db 8nm 81a 9nb
thanks
any rare equipment that might be worth some cash?
its in a scrap yard relatively complete
Old May 6, 2011 | 08:57 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: 85 trans am
Welcome to TGO. The first thing I see that's special is it comes with AAA protection from the factory!
I now need to look and see if anything really is special!
Old May 6, 2011 | 09:35 PM
JT's Avatar
JT
Community Administrator
Re: 85 trans am
A 305TPI/Auto, T-Tops, 3.27 positraction axle, 4-wheel disc brakes without WS6. Russet Metallic exterior with Chestnut aero package. Should (or did) have the large hood bird on the hood. Does (or did) have UQ7 which is a factory subwoofer option (slide gain switch on the cluster along with special rear speakers and likely Premium Sound badge on the stereo faceplate).
Old May 6, 2011 | 09:37 PM
davidj3594's Avatar
Re: 85 trans am
thanks
thanks
had all of that and it also had 71k original miles.and what about the b20 interior package?any other notable things?its seemed like the best equipped third gen ive ever seen
Old May 6, 2011 | 09:58 PM
JT's Avatar
JT
Re: 85 trans am
According to my 1986 source (which can differ from 1985 - a year I don't have), it shows B20 consists of:
Luxury Trim Group: includes custom seat belts, deluxe split folding rear seat, custom front bucket seats, deluxe door trim, dash-mounted map pocket, carpeted door kick pads, adjustable headrest, door map pockets (with power windows)
I'm not sure that's really special on a Trans Am.
D27 is rear compartment storage cover
B48 is Luggage compartment deluxe carpeting: includes carpet inserts on side, rear panels and spare tire cover
DK6 is Interior roof console
You'll probably want to get the DK6 - if it's still there.
Old May 6, 2011 | 10:04 PM
davidj3594's Avatar
Re: 85 trans am
the interior roof console is there.what do you think it will bring its in near mint shape
Old May 6, 2011 | 10:12 PM
JT's Avatar
JT
Re: 85 trans am
Someone else may have a better value, but I wouldn't expect a premium. Less than $100 for sure (from what I've seen). It's just worth saving, if possible, especially make sure it has the removable battery operated flashlight. Some like to buy one to install in their ThirdGen - even if it doesn't necessarily really add a lot of features itself.
Probably was a sharp car, in my opinion. But is missing some top-level features (WS6, digital cluster, CC1 T-Tops, for example).
Old May 6, 2011 | 10:19 PM
davidj3594's Avatar
Re: 85 trans am
ill look for the battery operated flashlight.it does have cc1 t tops.to be honest it still is a sharp looking car.it looks like a one owner car since it has a lot of original paperwork(in rough shape from it being exposed to rain with the t tops off in the yard but there including registrations up to about 2001 with the same owners name then a change to somebody in the family since the last name is the same)its in great shape for a colorado car with no rot anywhere. and the dash cluster in near new condition.its sad it ended up here since it looks like it was easily restorable when it showed up.
Old May 6, 2011 | 10:31 PM
JT's Avatar
JT
Re: 85 trans am
Correct. Sorry, I seen the CC1 in your list but mistakenly added that to the list rather than the optional seats.
With the original condition, if you happen to find the buildsheet (and it's any good) please let us know. Those help populate our RPO Decoder.
Thanks and good luck
Old May 6, 2011 | 10:57 PM
davidj3594's Avatar
Re: 85 trans am
where would the built sheet be at?under the drivers seat?
Old May 6, 2011 | 11:17 PM
JT's Avatar
JT
Re: 85 trans am
It can be just about anywhere (under carpet, behind instrument cluster, on top of fuel tank, under seat, etc.) - if even in the car. Just thought if you dig into the car, for any parts, to keep an eye out and save the buildsheet if you happen to find it.
Old May 7, 2011 | 01:36 AM
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
Re: 85 trans am
Sorry to hyjack, so I will make it minimal. I have the build sheet for my highly optioned original 29K miles WS6. Will that help with the RPO decoder?
Old May 7, 2011 | 02:29 AM
JT's Avatar
JT
Re: 85 trans am
Very much. We will be collecting all build sheets we can get. We've found that no one source appears to be complete (service manual, sales brochure, etc.) so we're pooling from all GM sources to make it as complete and accurate as possible.
You can email the build sheet to me at jt@thirdgen.org
Thanks for your help.
Old May 7, 2011 | 07:17 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: 85 trans am
Grab the UQ7 equipment. It might not be worth a whole lot right now, but that stuff's going to be hard to find soon.
Remove the:
1) Gain switch on the dash.
2) Amp behind the map pocket on the left (it's a metal box about twice the size of pack of cigarettes).
3) Sub box enclosures located behind the sail panels.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
