place to look for accurate code # for motor for a 84 Z28
Car: 84 Z28 Camaro
Engine: Z28,305
Transmission: 700R 4
Axle/Gears: stock
Just picked up my 84 Z28 it's Carb 305 but I've driven allot of 305s before and this one is way faster I want to know how to find out if it is a HO or not, dealership can't use the VIN # cause it is too old. Can anybody help?
Re: place to look for accurate code # for motor for a 84 Z28
You should have a G for the 8th digit of your VIN number for L69 HO 305. If it is H it is an LG4.
Car: 84 Z28 Camaro
Engine: Z28,305
Axle/Gears: stock
Thanks, the 8th digit is an H, but still this car does move quicker than any TBI 305s I've ever driven. Is that normal with Carb, I've always been told that fuel injection has a quicker response time than Carb? This car was purchased in Germany in 84 an it's been in the family ever sense. I haven't really had a chance to drive it much because of personal reasons, or I would know more. The thought is that there might be a different computer chip in this car. Any suggestions would be appreciated, thanks
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Export cars in some instances did not have the emissions and sometimes actually had a hotter cam. So it may be possible...
Chances are someone may have swapped another cam, or engine or parts to make it faster...
John
John
Car: 84 Z28 Camaro
Engine: Z28,305
Axle/Gears: stock
Being an export car makes sense, this was a floor model at a dealership so possibly it was ordered with special specs to the dealership, I guess won't know for sure. The motor just hit it's 90,000 mile mark bringing it home, gonna put some TLC into it and enjoy it, thanks again
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Theres casting codes on block driver side back need a mirror to see and codes on block pass front and do a search for iding gm block codes
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
mdtoren
Aug 16, 2015 05:45 PM
