Different flame red paint codes
Old Jul 5, 2011 | 08:37 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I had my car repainted last year and the only thing I told the paint shop was the RPO code 74U, I know now that there are two different codes for 74U depending on the year. What's the difference? Is it a different shade or is it really the same thing?
The reason I ask is because I want to have my doors redone due to some waviness, but I'm unsure what code they used.
Old Jul 5, 2011 | 09:04 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Different flame red paint codes
From 1987 & 1988 The WA number is 8748
in 1989 9535
Scott has the Flame Metallic Red on his 1987 IROC, We had this conversation a while back about the differences in color... he may know better than me.
John
Old Jul 6, 2011 | 07:50 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The 89 color seems to be a slightly deeper red. My neighbor has an 89 and mine is an 87 and his color is not the same as mine. Your painter probably used 74 for your year, not just 74. I'm sure most painters try to match the color for your year as they know the shades might change from year to year.
Old Jul 6, 2011 | 09:34 PM
okfoz's Avatar
One thing I do know from painting a few cars, the primer color will change the color of the top color...
John
Old Jul 6, 2011 | 10:45 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
John
Yep, I do believe the red oxide primer is best for this color. Unfortunately my painter used the light grey primer and I can see light spots when the sun hits it just right. I may end up repainting the whole thing, minus the bumpers and gfx since they seem to look okay.
I won't be using the same painter.
Old Nov 13, 2011 | 10:32 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
i love the flame red color, i'm painting mine soon. glad i found someone who could suggest the color primer that would be best!
Old Nov 14, 2011 | 06:37 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Most paint systems primers have a sealer thats used between primer and paint to help keep the primer colors from bleeding thru. Of course not all painters can lay down paint properly. Ive seen 3-4 factory flame red met cars and they all seem to be a diff shade.
Old Nov 14, 2011 | 08:40 AM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Grey primer is the standard for a red base coat. My car is 75U RED. When I did my engine bay I shot it with grey feather fill G2 and dupont 75U blaze red on top. Its a perfect match. Shades can also change with how your gun throws met. If its not perfectly mixed you will see a different shade.
Old Nov 14, 2011 | 01:15 PM
okfoz's Avatar
I guess you should also note that all cars from the factory had the same color primers for any particular year. The Medium Gray is what I tend to remember.
Some cars I have seen where the original primer on the front "Doghouse" and the back of the car were different, Many older cars the front clip was primed Black IIRC,, and then shipped to be assembled on the car. The back of the car was painted Gray... Of course it could have been the other way around, my memory is a bit vague.
Ultimately the front clip and the back of the car did not match in all cases.
John
Old Nov 7, 2012 | 06:54 PM
Jimmy64D's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
Old thread:
89 IROC, RPO 74Q and 74U. 74Q=Flame Red Metallic GFX and 74U=Victory Red Body. Pretty sure they should both be same, right?
Old Nov 7, 2012 | 07:27 PM
scottmoyer's Avatar
There was no Victory Red. It was either Bright Red or Dark Red Metallic. Pontiac referred to the Dark Red as Flame Red. Victory red is bright red. Code 74 is Dark Red Metallic.
Old Nov 8, 2012 | 12:46 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Originally Posted by Jimmy64D
Old thread:
Code 74 Victory Red is a 2005-09 Corvette color...
Old Nov 8, 2012 | 05:05 PM
Jimmy64D's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
I am pretty sure my car is flame red, but the RPO decoder says Victory. Thanks for the confirmation.
Old Nov 8, 2012 | 06:01 PM
scottmoyer's Avatar
If you have a Camaro, you do not have "Flame Red". You have Dark Red Metallic. Which RPO decoder says Victory Red? Most RPO decoders use the 1991 code specs which are wrong in so many areas. Lower stripe colors are almost always incorrect because of this.
Old Nov 8, 2012 | 11:25 PM
JT's Avatar
JT
Community Administrator
It might be our current RPO Decoder (the one that we're working toward replacing) as 74U does show Victory Red (91).
Old Nov 9, 2012 | 07:37 AM
okfoz's Avatar
Just an FYI to everyone posting Color RPO codes... The first two numbers are the only important portion of the RPO for determining color... IE 74 = The Red color... U = Upper, L = Lower P = Wheels, etc...
In 1991 & 1992, the "Chevrolet Passenger car color Chart" called #74 "Flame Red Metallic"
John
jaridjohn
Jul 8, 2024 03:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
Golfvette
Aug 24, 2015 06:35 PM
