Some '85, yellow IROC, updates.....
Old Oct 11, 2016 | 08:08 AM
  #551
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Some '85, yellow IROC, updates.....
After:
Old Oct 11, 2016 | 08:58 AM
  #552
ev305tpi's Avatar
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
That came out great Charlie!! awesome!! I did the same with my previous 87 GTA. It's the only way to get a good match.
Old Oct 11, 2016 | 09:18 AM
  #553
chazman's Avatar
Axle/Gears: BW 3.45
Thanks Erik. I agree, that's the only way to get an invisible repair. Had I used new fabric, you'd spot the repair a mile away.
Did the same thing to my purple '92 driver's seat.
Old Oct 11, 2016 | 03:10 PM
  #554
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
That turned out great!
Old Oct 11, 2016 | 04:40 PM
  #555
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Is removing the cloth from the seat as easy as I think it is? Id like to just throw mine in the washer too...
Old Oct 11, 2016 | 06:03 PM
  #556
chazman's Avatar
Axle/Gears: BW 3.45
Thanks!
Old Oct 11, 2016 | 06:06 PM
  #557
chazman's Avatar
Axle/Gears: BW 3.45
Well, you've got to find all of those hidden hog rings. But I remember thinking that I was glad I didn't have to put this cover back on.
Old Oct 12, 2016 | 04:29 PM
  #558
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
I see.
Did you happen to take the cloth off of the headrest too? A previous owner removed the seat belt guides and mounting piece inside the headrest has shifted and the only way to get to them is to take apart the headrest.
Old Oct 12, 2016 | 06:02 PM
  #559
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I have taken the cloth off of the '82 as recently as this weekend. I didn't remove the headrest itself. Lift the head rest to it's highest position and using a pair of pliers, carefully grip the zipper. The zipper tag that you normally use to open and close a zipper wasn't on mine, so I just grabbed the part the tag would connect to. It made it simple to unzip. From there, start at an inside corner, compress the foam enough to get the cover over the corner. Do this on the other inside corner until you have one side out. From there, you should be able to work the cover off of one side. Once loose, the other side lifts right up off of the foam. You should be able to put the seat belt guide back together at that point. I had to use a much larger screw through the metal plate because the hole was stripped. It works great now.
Old Oct 12, 2016 | 06:36 PM
  #560
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Thank you very much.
Old May 1, 2017 | 04:29 PM
  #561
chazman's Avatar
Axle/Gears: BW 3.45
One of my winter projects was replacing my old beat up stripes with new ones on my yellow, '85. I removed the stripes yesterday. Better late than never! Looks kind of cool without them. I left that one stripe in front of the wheel because it was perfect and might help guide me with the new stripes.
Old May 2, 2017 | 03:30 PM
  #562
DynoDave43's Avatar
It does look nice without it. Great looking car either way.
Old May 2, 2017 | 03:59 PM
  #563
chazman's Avatar
Axle/Gears: BW 3.45
Hopefully I'll get the new stripes on this weekend.
Old May 3, 2017 | 07:38 PM
  #564
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Axle/Gears: 373 Limited Slip
Nice work! I love the yellow IROCs!
Old May 4, 2017 | 11:54 AM
  #565
chazman's Avatar
Axle/Gears: BW 3.45
Thanks!
Old May 4, 2017 | 01:04 PM
  #566
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Woah,that at does look as good "naked" as it does with the stripes. If the black door molding was gone or yellow it would look a bit cleaner but outstanding either way!!
Old May 4, 2017 | 01:40 PM
  #567
chazman's Avatar
Axle/Gears: BW 3.45
You know Tony, I kind of like it without the stripe! I already have the Phoenix stripe kit though, and will probably put them on this weekend.
But......I have been known to procrastinate!
Old May 4, 2017 | 01:44 PM
  #568
chazman's Avatar
Axle/Gears: BW 3.45
This is also one of those cars with a screaming fuel pump after 35 minutes of driving on a warm day. I replaced the clogged canister filter with no changes. I just bought a vented GM fuel cap. We'll see what happens with that......
I should also probably remove, disassemble and clean my fuel tank valve.
Old May 5, 2017 | 11:27 AM
  #569
yo soy el warg's Avatar
I have to agree with TTOP350. My 1985 is red and had the black door moldings on it. I had an extra set of door moldings for the car so I removed the black ones and sprayed the other set with red vinyl paint to match the car. By doing this I was able to remove all the old residue that had built up above and below the original door guards.
The 1986 models came from the factory with color matching door guards. If your lucky enough to find a yellow set that would make things easier. This was a 100% improvement on my red 1985. It was easy to remove the black guards once I heated them up like you did to remove the stripes on your car. The hard part was getting them back on straight.
To do this I temporarily taped a 3 foot yard stick with masking tape on the door just below the spot the door guards were going to go back on so they would be level. I put double sided 3m tape on the back of the trim before I painted them red so the edge of the double sided tape also got painted red and blended much better than the greyish color of the 1/32" edge of the double sided tape that mainly shows on the top side of the door guard trim. Leave the paper on the sticky backing of the tape till you are ready to put them on.
The door guard trim strips have a metal strip in them and can get bent up or down. I just carefully straightened them before painting them. All of this was a pain to do but well worth it if you want to keep the guards on the door. It is surprising how much better looking this one little detail can be to blend the the side body lines on a third gen. You can always go back to the original black ones if you want to keep it totally original. I think these cars look the best with no door guard, but if you totally remove them at this time there may be some paint fading that shows above and below where the strip had been.
Old May 7, 2017 | 05:47 PM
  #570
chazman's Avatar
Axle/Gears: BW 3.45
Stripes back on! Ready for ThirdGen Expo!
Old May 7, 2017 | 07:20 PM
  #571
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Looking Good.
Old May 8, 2017 | 02:53 AM
  #572
Your car looks outstanding with the new stripes. I have always liked the gold wheels and tan interior color combination with the yellow exterior. For the third gen body style this is the super stand out combo !!!!!!!!!
Old May 8, 2017 | 06:47 AM
  #573
L67ss's Avatar
I screenshotted those last pics to send to my brother to motivate him on his yellow iroc
Old May 8, 2017 | 06:54 AM
  #574
L67ss's Avatar
We were just looking at a Phoenix stripe kit for his car too
Old May 8, 2017 | 08:56 AM
  #575
chazman's Avatar
Axle/Gears: BW 3.45
Originally Posted by mantaguy
Looking Good.
Thanks guys!
Old May 8, 2017 | 08:57 AM
  #576
chazman's Avatar
Axle/Gears: BW 3.45
Have your brother get the more expensive premium kit, (or whatever it's called). Those are exact replacements.
Old May 8, 2017 | 12:41 PM
  #577
L67ss's Avatar
Will do thanks
Old May 10, 2017 | 06:24 AM
  #578
DynoDave43's Avatar
Looking good!
Old May 10, 2017 | 08:53 AM
  #579
chazman's Avatar
Axle/Gears: BW 3.45
Looking good!
Thanks Dave!
Old May 13, 2017 | 08:32 PM
  #580
chazman's Avatar
Axle/Gears: BW 3.45
How a 2 minute wipe down turns into a 90 minute project.
I was wiping down the dash of my '85 in preparation for Expo when I notice some spots on my speedo lens. Wipe them, still there. Use a stronger cleaner, still there. This stuff bugs me. Call me weird if you want, I don't care. So I removed the bezel and lens and started polishing......
More polishing......
Finally after an hour, whatever those "spots" were, were gone.
BTW, if your IP lens is cloudy and scratched, remove it and polish it. It'll look like new and make you feel a whole lot better about driving your 3rd gen!
Old May 15, 2017 | 09:17 PM
  #581
DynoDave43's Avatar
I used the same product on my cluster lens last year, with the same great results. I highly recommend this easy and inexpensive improvement.
Old May 15, 2017 | 09:52 PM
  #582
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
My lens has a deep scratch in the temp gauge area. Having a heck of a time finding one to polish up like yours.
Looks great!
Old May 16, 2017 | 09:11 AM
  #583
chazman's Avatar
Axle/Gears: BW 3.45
Thanks guys. I actually polished the lens when I first got the car. It's part of my deep cleaning regimen.
It was just those new darned mystery spots that needed polishing out.
Old Jul 11, 2017 | 09:14 PM
  #584
chazman's Avatar
Axle/Gears: BW 3.45
Testing Flickr
Old Jul 11, 2017 | 09:49 PM
  #585
chazman's Avatar
Axle/Gears: BW 3.45
More Flickr.......you blow photobucket!
Old Jul 11, 2017 | 10:23 PM
  #586
chazman's Avatar
Axle/Gears: BW 3.45
Take a hike photobucket, never liked you anyway...
Old Jul 12, 2017 | 09:02 AM
  #587
mantaguy's Avatar
Engine: 5.0 EFI
Thanks Chaz I just signed up on Flickr also.
PHOTOBUCKET SUCKS
Old Jul 13, 2017 | 08:09 PM
  #588
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Charlie Im sure its somewhere in this massive thread but ill just ask.
What month was this car built?
  #589
chazman's Avatar
Axle/Gears: BW 3.45
What is the build month for this 85?
May.
Old Jul 13, 2017 | 08:18 PM
  #590
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
May.
Interesting. I was talking to an original owner of an 85 at the annual Camaro show out here and he was saying that GM had some trouble with yellow in 85 and thats what prompted them to introduce white for the IROC-Z in mid year.
Maybe that was just the Norwood plant though.
Car looks amazing Charlie.
Old Jul 13, 2017 | 09:29 PM
  #591
chazman's Avatar
Axle/Gears: BW 3.45
Thanks Brad. Photobucket boned this thread by deleting years worth of photos. I may go back and add some from time to time.
Old Aug 8, 2017 | 10:34 PM
  #592
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Anymore updates? I love this car.
Old Aug 8, 2017 | 11:54 PM
  #593
chazman's Avatar
Axle/Gears: BW 3.45
Thanks! Car is currently chillin' at my parents. I need to get a lift in order to bring it back home
Old Sep 3, 2017 | 11:00 PM
  #594
chazman's Avatar
Axle/Gears: BW 3.45
Brought the yellow '85 back home and took the '87 to my parents. I parked it in the garage last night and noticed what looked like a bunch of dirt on the hood around both louvers - except the dirt was moving. It was a big black mama spider with hundred of baby spiders coming out of the louvers.
I think I got 'em all.
Got it out of mom's garage just in time!
One obvious observation. After dropping off my LG4 '87, and bringing home my '85 - an L69 cammed LB9 with a 3.42 gear is A LOT faster than an LG4 with a 2.73.
Anyway, a bunch of little things I need to do to it. I must have an AC leak, because it needs a recharge. Maybe I'll have time tomorrow.
Old Sep 4, 2017 | 11:15 AM
  #595
chazman's Avatar
Axle/Gears: BW 3.45
AC doesn't need a recharge. Low pressure switch is bad - again! I just replaced that thing a couple of years ago. It can't have more than 20 hours on it. Damned cheap Chinese parts!
Old Sep 4, 2017 | 01:01 PM
  #596
chazman's Avatar
Axle/Gears: BW 3.45
Old Sep 4, 2017 | 05:01 PM
  #597
chazman's Avatar
Axle/Gears: BW 3.45
Nevermind. And I blamed the Chinese.
It just needed a little shot of 134.
I thought it was the low pressure switch because I could jump the compressor with a paperclip.
Old Sep 4, 2017 | 11:34 PM
  #598
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Need more pics of this car!!
Old Sep 5, 2017 | 08:04 AM
  #599
chazman's Avatar
Axle/Gears: BW 3.45
I'll get some new ones up soon.
Photobucket is holding most of the previous pics in this thread hostage.
Here's a quicky from this morning:
Old Sep 5, 2017 | 08:12 AM
  #600
mucker15's Avatar
Car: 1989 Iroc 5.7 1969 Camaro 2010 SS
beautiful car nice job
