Some '85, yellow IROC, updates.....
Old Sep 5, 2017 | 09:57 AM
  #601
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Some '85, yellow IROC, updates.....
Originally Posted by mucker15
beautiful car nice job
Thanks!
Old Sep 6, 2017 | 08:33 AM
  #602
George Klass's Avatar
Car: 1989 Trans Am
Kai gamo! Don't know how I missed this thread, mint car!!!
Old Sep 6, 2017 | 09:11 AM
  #603
chazman's Avatar
Axle/Gears: BW 3.45
Thanks Yiorgo!
Old Sep 11, 2017 | 09:26 AM
  #604
chazman's Avatar
Axle/Gears: BW 3.45
I think my sending unit is bad. The gas gauge has been over FULL for the past 70 miles. The last tankful I also noticed that the gauge was getting sluggish.
Looks like dropping the tank will be a winter project.
Old Sep 12, 2017 | 09:12 AM
  #605
82tarecaro's Avatar
I have the same issue with the tta. What sending unit are you going to use to replace it? The Spectra unit? I don't really like the brand.
Old Sep 12, 2017 | 09:53 AM
  #606
chazman's Avatar
Axle/Gears: BW 3.45
I haven't really researched yet. I put some MMO in the tank and the needle started moving. Not accurately, but at least moving from full to 3/4. Techron is supposed to be good for cleaning sulfer from the sending unit. I'm going to try that as well.
Old Sep 12, 2017 | 10:12 AM
  #607
82tarecaro's Avatar
I got mine to move with techron, but it is never accurate. It reads half when the tank is empty. I found out the hard way. I think it is inevitable that the sending unit needs to be changed.
Old Sep 12, 2017 | 10:22 AM
  #608
chazman's Avatar
Axle/Gears: BW 3.45
I agree.
I guess GM sending units are susceptible to fouling from high sulfer in fuel. A lot of good results on the Corvette forums from Techron. I happened to have a bottle of Techron injector cleaner in the garage so I threw it in last night, but you're supposed to use the stronger Techron concentrate. According to some of the Corvette posts, some have gotten literally instant results and other have required 2 or 3 tankfuls.
Old Sep 12, 2017 | 10:53 AM
  #609
82tarecaro's Avatar
I might give it another shot. I want to put a bigger pump in anyway, so I might drop the tank in the spring.
Old Sep 12, 2017 | 12:42 PM
  #610
chazman's Avatar
Axle/Gears: BW 3.45
Just put 20 ounces of Techron concentrate in and topped it off with 8.1 gallons of Amoco premium. I'll drive it for a couple of days and see what happens.
Old Sep 12, 2017 | 05:00 PM
  #611
chazman's Avatar
Axle/Gears: BW 3.45
Me and my crew last Friday night. Last cruise night of the season.
My yellow '85, next to my friend's 33K mile, '86 Mustang GT, 5 speed, t-top, next to my other friend's original paint, low mile L-78, 4 speed Nova, next to my other friend's, RA II, 4 speed convertible, '68 GTO, (his father bought it new), next to my other friend's 16,000 mile, all original '67, 427 Impala.
Old Sep 12, 2017 | 06:26 PM
  #612
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
All of your friends have great taste in cars.
Old Sep 12, 2017 | 08:59 PM
  #613
chazman's Avatar
Axle/Gears: BW 3.45
They're a great group of guys! Who do you think is going to help me drop the tank!?
Each one of those cars has a great story to it.
That white GTO, for example. All five of us spent all winter doing a substantial freshening on it, almost a minor restoration. The car was bought by the owner's dad off the showroom floor. He kept telling everyone it had an "experimental motor" but no one knew what that meant. After his dad passed away, he took ownership of the GTO and pretty much parked it. BTW, it has about 38K miles.
One day about a year or so ago, my friend with the blue Impala was checking it out and noticed it took more than four rotations of the wheels to rotate the DS, (it has 4.33 gears). He suggested that he have the car PHS'd. It turned out to be a one out of 199 RAII GTO's ever produced during a 2 month period in 1968. Maybe 20-ish are left in any condition on the planet. Anyone into these cars knows how much it's worth. Let's call it a $$$buttload$$$.
Old Sep 15, 2017 | 05:02 PM
  #614
chazman's Avatar
Axle/Gears: BW 3.45
Man, this car is becoming a problem child. Now it looks like the water pump is leaking. Oh well, on the bright side, I've meaning to change a couple belts, anyway.
Old Sep 16, 2017 | 10:53 AM
  #615
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Charlie, why do you think the fuel sending unit is bad? I had to replace my fuel gauge to resolve an incorrect reading.
Old Sep 16, 2017 | 11:31 AM
  #616
chazman's Avatar
Axle/Gears: BW 3.45
It's possible it could be the fuel gauge. Was yours stuck above FULL? Did you test your gauge?
Old Sep 16, 2017 | 02:47 PM
  #617
scottmoyer's Avatar
Mine would get stuck above full because when starting the car, the gauges would all peg, then settle to their proper spot. The Fuel gauge required me tapping the IC to get it to be unstuck.
I tested my gauge by using an old fashioned voltmeter that had a needle. My needle would either stick, or dance all over. With the voltmeter, it read a consistent voltage while the gauge was dancing, so I replaced the gauge. I've been good since.
You could easily test the gauge with the one from the other car!!
Old Sep 16, 2017 | 03:33 PM
  #618
82tarecaro's Avatar
You could test it at the tank. When grounded, the gauge should go to empty.
Old Sep 19, 2017 | 09:10 PM
  #619
Car: 1989 Trans Am
The crew has nice cars!
Old Sep 20, 2017 | 09:45 AM
  #620
chazman's Avatar
Axle/Gears: BW 3.45
Yeah, thanks. You don't think about it when you are around the cars all the time, but that there is a nice collection of desirable cars.
Old Sep 23, 2017 | 11:42 PM
  #621
Drew's Avatar
For my dumpster divin' project Bird, I never drove the car, so no clue if the gas gauge worked. While I had the tank out, I hooked up the voltmeter and moved the sender float to see if the readings changed - nada. Moved the float back and forth a few times, with nothing more than an occasional glitch on the meter. Sprayed WD-40 in the whatever, the ghetto potentiometer driven by the float assembly, and ran the float back and forth a few more times. Started reading normal, and consistent. Now I'm still a ways from finding out if it'll keep working, but I found it interesting that so little got it working. I was all set to open the thing up and try cleaning it more directly. FWIW.
Old Oct 7, 2017 | 11:24 AM
  #622
chazman's Avatar
Axle/Gears: BW 3.45
Question: How many middle aged dudes does it take to change a water pump? Answer: Four. With plenty of ballbusting and story telling!
Actually, that's pretty much what we mostly do anyway. The water pump was just an excuse to have a garage night.
Old Oct 7, 2017 | 04:49 PM
  #623
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
I'm about a year late with this, but what's the best method for washing seat covers in the washer? I don't know how to do laundry, lol. And I'm assuming it's best to let them air dry?
Also, have any more pictures of your friends 427 Impala?
Old Oct 7, 2017 | 07:26 PM
  #624
chazman's Avatar
Axle/Gears: BW 3.45
Welp, I'm not a laundry expert, but this is how I did it. Put the covers in the washing machine, add soap and press START.
Yes, I let them air dry.
I'll see what pics I have on my phone, anything you'd want to see in particular?
Old Oct 7, 2017 | 07:44 PM
  #625
Engine: that I like
Lol, I didn't know if water temp or something made a difference.
Nothing in particular, I just love full sized Chevy's. Especially '65-'70. You can put them in a pm if you rather, at your leisure.
Old Oct 7, 2017 | 08:28 PM
  #626
chazman's Avatar
Axle/Gears: BW 3.45
Honestly, I don't remember, but I think I avoided extreme temps.
Old Oct 7, 2017 | 08:55 PM
  #627
chazman's Avatar
Axle/Gears: BW 3.45
Here you go.
These were from a couple years ago when he first got it. It was parked since 1972. The original owner was a GM tech and stored and maintained it impeccably. We still spent the winter going through the whole car before driving it. The car is magnificent, probably the best original '67 Impala in the country. When parked next to $200,000 restorations at MACACN, it makes those cars look like artificial cartoon cars. Original is original.
Old Oct 8, 2017 | 02:37 PM
  #628
Engine: that I like
Wow, such a time capsule! I see a couple non-stock items like the wider rims (which is what Chevy should have ran in the first place) but one thing has me confused. Dual underhood lamps? One of those was added on, correct?
Old Oct 8, 2017 | 03:44 PM
  #629
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
Hey chazman, just found this thread. Outstanding car, by far my favorite color iroc. Here's a pic of one running around town I've been spying on.
Old Oct 8, 2017 | 10:41 PM
  #630
chazman's Avatar
Axle/Gears: BW 3.45
Good eye!
The original owner was a mechanic at a Chevy dealer and did his own customizations using GM parts. The trunk has dual lights as well. There are a few other custom touches as well, like Caprice tail lights and export windshield wipers which sweep towards the center.
As we were bringing it back to life and discovered these "back in the day" touches, we decided they were an important part of the car's history and left them as is.
Old Oct 9, 2017 | 11:56 AM
  #631
chazman's Avatar
Axle/Gears: BW 3.45
I've had an oil leak since I've owned this car. I've always felt that it was leaking from high up in the engine. I asked my friend to bring his flexible inspection camera when we did the water pump and now I suspect the oil sending unit area behind the distributor on the driver's side.
Any thoughts?
Old Oct 9, 2017 | 12:57 PM
  #632
chazman's Avatar
Axle/Gears: BW 3.45
For sale or just someone's car?
Old Oct 9, 2017 | 04:34 PM
  #633
Engine: that I like
Any thoughts?
The oil sender would be a very likely culprit. Especially if it seems like sometimes it leaks more than another. When they get worse, you can have a very bad oil leak that is actually intermittent.
And I did not notice the Impala's wipers!
Old Oct 10, 2017 | 12:00 AM
  #634
chazman's Avatar
Axle/Gears: BW 3.45
Any tips on replacing it? I'd imagine removing the distributor would give more work space.
Old Oct 10, 2017 | 12:03 AM
  #635
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Just a random car around town, but man it's cool.
Old Oct 10, 2017 | 12:05 AM
  #636
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Don't pull the distributor, I just did mine, it's a bit of a pain but can be done without removing anything. Did mine from driver side. The only thing that made it hard was threading the new one in amoungst the wiring harness.
Old Oct 10, 2017 | 12:15 AM
  #637
chazman's Avatar
Axle/Gears: BW 3.45
Thanks!
Old Oct 10, 2017 | 11:33 PM
  #638
daveb123's Avatar
Car: 82 Z28
Transmission: BW T-10
Good eye!
Awesome car! Always liked the mid 60s big Chevys. Did anyone notice he also put a Caprice rear bumper on it so it would have reverse lamps? Impalas had them in the taillights.
Old Oct 11, 2017 | 01:30 AM
  #639
chazman's Avatar
Axle/Gears: BW 3.45
Yup! Another good eye!
Old Oct 11, 2017 | 06:04 PM
  #640
chazman's Avatar
Axle/Gears: BW 3.45
Just to verify, did you replace the oil pressure switch or oil pressure sender? I believe they are next to each other back there.
Old Oct 11, 2017 | 06:36 PM
  #641
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Replace both!
I had the switch (2 prong plastic unit) let go on me this summer when I was (luckily) 2 streets from home...when I just happened to glance down and see the oil pressure gauge at zero.
Get it home and the chassis is covered in oil. A few ounces remained in the pan.
So...cheap insurance to do both. My switch had been leaking for some time I think. I have virtually no oil leak from the back of the pan anymore. I assumed it was a rear main seal, but I think that switch had a slow leak.
Old Oct 11, 2017 | 06:47 PM
  #642
chazman's Avatar
Axle/Gears: BW 3.45
Replace both!
Any secret ninja tips in getting access to both?
Old Oct 11, 2017 | 06:51 PM
  #643
Engine: that I like
I agree, replace both of them. Either can cause the same leak and I'm assuming they are both original.
Old Oct 11, 2017 | 06:57 PM
  #644
Engine: that I like
Just getting the cap and wires out of the way is usually enough. I'm trying to remember the exact setup right now, is it the switch on top and the sender sticking off to the side of the tee? I'm far away from my car to look for myself.
A socket for the switch usually helps a bunch.
Old Oct 11, 2017 | 07:11 PM
  #645
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
The gauge sending unit you can get with an open ended wrench, but the switch needs an Oil Pressure Switch socket. You cannot fit a normal socket on it.
Old Oct 11, 2017 | 09:27 PM
  #646
chazman's Avatar
Axle/Gears: BW 3.45
Brad, it seems like a deep socket should work on the switch. No?
Old Oct 12, 2017 | 07:09 PM
  #647
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
It has to be the special socket. Normal sockets won't fit.
Old Oct 12, 2017 | 09:42 PM
  #648
Engine: that I like
And those sockets come in a few ways. Shallow, deep, and also a flat crow's foot type.
Old Oct 12, 2017 | 10:40 PM
  #649
chazman's Avatar
Axle/Gears: BW 3.45
I may have to borrow my friend's camera and get one more look back there. With a flashlight it looks dry back there. But I see oil on the intake between the front and rear pair of runners on the driver's side.
Old Oct 13, 2017 | 07:31 PM
  #650
Engine: that I like
The intake bolts thread into the open lifter valley, it's possible for oil to wick up the bolts and pool up a bit on the intake manifold.
