Hey guys, I'm getting my hands on an 89' iroc. Or at least I think it's 89. And I'm pretty sure it's an iroc. Anyways, what's the best way to ID this vehicle, also what are rpo codes? Any help would be greatly appreciated.
JamesC
close
navy02ws6
close
Look at the VIN. If the 8th digit is an "F" or an "8", then it's an IROC. If it's an "E", then it may or may not be an IROC, and you'll need to do some more research.
if its not an iroc its definetly a z28. it's a tpi, but idk if its a 305 or a 350, thanks for the help.
Quote:
Regarding the year . . . the VIN's tenth digit will tell you . . .Originally Posted by fastrs1891
Hey guys, I'm getting my hands on an 89' iroc. Or at least I think it's 89. H=1987
J=1988
K=1989
L=1990
M=1991
Got the rpo codes. It's an 86' iroc. It gots the z28 and B4Z. Codes. And it's a 305. Thanks for the help
Hey guys, maybe there's something else y'all can help me with. This iroc has a vbelt set up. What exactly would I need to switch it to a serpentine? Are there any good kits available?
JamesC
close
Quote:
Here's the GM kit that I used:Originally Posted by fastrs1891
Hey guys, maybe there's something else y'all can help me with. This iroc has a vbelt set up. What exactly would I need to switch it to a serpentine? Are there any good kits available? https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
If it's an '89 it should NOT have the Vbelt setup... Its not an '89 or it's had a motor swap. Or someone just swapped the accessories for some unknown reason....
Quote:
You guys need to read more than just the heading when responding to posts. Just a few posts up, he stated that the car is an '86.Originally Posted by 1MeanZ
If it's an '89 it should NOT have the Vbelt setup... Its not an '89 or it's had a motor swap. Or someone just swapped the accessories for some unknown reason.... Supreme Member
Quote:
I read the whole thread before I responded. I simply missed the year man cut me a break.Originally Posted by scottmoyer
You guys need to read more than just the heading when responding to posts. Just a few posts up, he stated that the car is an '86. My response was directed at everybody that responds to just the last post or responds to just the title and doesn't read everything else. I've seen it happen many times that people respond either incorrectly based on original thoughts or they respond incorrectly because of they just didn't read the thread. I'm just sayin'
