1987 trans am with 61000 original miles, swap engine?
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
Bought a 1987 trans am with 61000 original miles on it. Car sat for 15 years and the spun main bearing in original lg4. Previous owner put a truck 350 in it. With the miles should i leave the 350 in it or try and put a lg4 back in the car
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 1987 trans am with 61000 original miles, swap engine?
Leave the 350.If your looking for originality it wouldn't make any difference if you put a LG4 back in because it wouldn't be nos.matching anyway.But the 87 did come with 350s from the factory.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Agreed... my first 3rd Gen was an LG4 car, and it too spun a bearing, I wanted the car to be "all original" thinking it would be worth more... regretted it ever since.. I quickly learned that the LG4, was slightly better than the V6, only because there was less to change when swapping engines. Keep the 350...
Car: 86 Trans am
Engine: LG4
yea car has the 350 carb in it, so at least its still a carbed engine. However previous owner said engine came out of a truck and doesnt know the miles on the engine. I am going to try and get cast numbers for block and heads this weekend to see what i am dealing with
I would voice the opinion of fixing the engine that is in it, so the car remains a reasonably low mile original car. TO ME it is worth far more that way. Although, still not worth alot....either way.
midge...did you mean 305 in it? LG4s are 305s.
Car: 86 Trans am
Engine: LG4
no i meant 350. The original 305 spun a main bearing after sitting for 15 years so the p.o. removed it and put a 350 in it
Car: 86 Trans am
Engine: LG4
So i pulled valve covers and it has 193 swirl port heads on it, same set up i originally had in my 15th anniversary trans am till i switched out for vortec heads, not sure what im going to do to this engine yet
colton_carlson
03-08-2019 12:21 PM
beachrodder
08-25-2015 08:05 AM
