Need some more 92 T/A answers!
Old Dec 18, 2001 | 05:30 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Can anyone answer me on these few questions:
1. Was rear discs optional or standard on 92 T/A's? If not, what options gave rear discs?
2. Is the rated 245hp for the L98 with or without dual cats. Also, was dual cats standard for this year?
3. Was the Th700r4 the only available Auto for 1992?
Thanks,
Ken
Old Dec 18, 2001 | 07:05 PM
p.haze92's Avatar
1)G92 coded cars came with the rear discs only I believe.
2)With dual cats only on Camaro's, the T/A's had 235 or 240hp due to different inlet tract.
Old Dec 18, 2001 | 07:07 PM
p.haze92's Avatar
Hit the enter button too early.
3)Yes
Old Dec 18, 2001 | 07:46 PM
92TRANSAMWS6's Avatar
Nope, my car isn't a G92 but it has 4 wheel discs... they were also a part of the WS6 option.....yet 92GTAs car doesn't have them...strange.
Old Dec 18, 2001 | 08:05 PM
92GTA's Avatar
From my understanding you could not get rear disks with the 305/auto combo. When the buyer of my GTA ordered it with the 305 then deleted the 5-spd and ordered the auto the rear disk were deleted and he said he could not order them at time either. This was also in the early 92 model year too when they were having problems with the rear disks so that might be why in my GTA's case.....
Old Dec 18, 2001 | 10:08 PM
p.haze92's Avatar
Sorry guys, forgot that pontiac didn't use the G92 code. My mistake.
Old Dec 18, 2001 | 10:22 PM
92GTA's Avatar
Actually Pontiac DID use RPO G92 as an option group or an indiviual option if you deleted what it usually came with, it later became part of the R6P option group though.....
If my GTA had the standard 5-spd it would have R6P option group with the G92, N10, etc......
Old Dec 18, 2001 | 10:37 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
240HP for 92 GTA.
Old Dec 19, 2001 | 12:30 PM
Drew's Avatar
Since you're asking about a 92 T/A and L98 I'll assume you're asking about that combo. For 92 the L98 required dual cats and rear discs, the only exceptions were if the car falls in with the group that had the discs deleted. The HP specs for pretty much every L98 Pontiac 88-up from what I've seen are very questionable. Having worked with both the Camaro and Firebird I can't see any reason why the L98 in the Camaro would really have any more power than the same engine int he Firebird. My conclusion is that GM skewed the numbers for their own marketing reasons the same as they have been doing since the 60's.
Old Dec 19, 2001 | 01:08 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Thanks a lot for all the info guys! I really appreciate it!
Ken
Old Dec 19, 2001 | 01:49 PM
karfreek's Avatar
The intake for the camaro went over the radiator behind the bumper. The Formula/GTA/TA have the ducting that goes around the radiator to a VERY restrictive air canister.
Jay
Old Dec 19, 2001 | 06:40 PM
Drew's Avatar
Ok we all agree that the factory horse power numbers are taken from the crank, why would they dyno the engines with different intakes? Besides that the Camaro intake has one advantage over the Firebird in the intake system, and thats the place where it picks up air. Both intake ducting setups are equally restrictive. Look at a camaro airbox before the air silencers are removed and tell me thats not more restrictive then the 3" round opening on 88-92 Firebirds. The intake ducting is only a reasonable argument for 85-87 TPI firebirds since their system was totally whacked in the head.
Old Dec 19, 2001 | 11:08 PM
karfreek's Avatar
The camaro picks up cool fresh air from behind the bumper. The Firebird gets warm air from the engine compartment. The opening in the canister is not very big either.
The engines have to be dynoed as they sit in the car, so the ducts would have to be attached.
Jay
Old Dec 20, 2001 | 08:39 AM
Administrator
Say what u like, both Firebird intakes are more restrictive and not designed as good as the Camaros, and thats what I think made the difference, even if they estimated it. I also agree with the previous post.
2012sergen11
Oct 13, 2015 07:38 PM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
92projectcamaro
Sep 29, 2015 07:07 PM
