C4B RPO Code
Old Oct 28, 2016 | 12:31 PM
1987L69's Avatar
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
C4B RPO Code
So I know the C4B RPO is PERFORMANCE PACKAGE ENGINE UPGRADE. But what did that include? Mine is on an LG4/T5 car.
Old Oct 28, 2016 | 01:01 PM
yo soy el warg's Avatar
Re: C4B RPO Code
This is what I found. This window sticker says it is a double play value option on a 1985 Z28 Camaro so it may be a cassette player option?
https://www.thirdgen.org/forums/hist...option-ya.html
Old Oct 28, 2016 | 02:46 PM
1987L69's Avatar
Car: 1984 Z28
Re: C4B RPO Code
Mine is an 84, and mine is a factory radio delete car. so what would C4B be then?
Old Oct 28, 2016 | 03:01 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: C4B RPO Code
Is it stamped on the block?
http://www.chevy-camaro.com/chevy-ca...es.asp?group=2
Old Oct 28, 2016 | 03:20 PM
1987L69's Avatar
Car: 1984 Z28
Re: C4B RPO Code
Yes, but why would they list it in the RPO code list?
Old Oct 28, 2016 | 05:51 PM
Re: C4B RPO Code
Does your RPO list have UL5 for the radio delete. Does it have any of these RPOs, U63, U69, YE1, YE2,YE4,YF1, or UT4 on Berlinetta models. Which are various radios and stereo systems for 1984. If it is a factory radio delete order I think it should have the UL5 listed and none of the radio RPOs should be listed. Just trying to figure out why you have the C4B if it is an engine option as it is on your car's RPO list?
Old Oct 28, 2016 | 06:36 PM
1987L69's Avatar
Car: 1984 Z28
Re: C4B RPO Code
yes it has UL5
But not any other other of the RPO's you posted.
Old Oct 28, 2016 | 11:01 PM
Re: C4B RPO Code
Is the 5th digit of your VIN an "S" or "P"?
Old Oct 29, 2016 | 06:16 AM
1987L69's Avatar
Car: 1984 Z28
Re: C4B RPO Code
The 5th didget is a "P"
Old Oct 29, 2016 | 08:45 AM
1987L69's Avatar
Car: 1984 Z28
Re: C4B RPO Code
Here are all of my RPO codes.
AR9 AU3 A01 A31 A90 B18 B34 B35 B84 B9K B94 B97 CC1 CD4 C4B C49 C60 DK6 D02 D1J D34 D35 D42 D80 D88 E5Z E6E E9Z GU5 G80 J65 K19 K34 K64 LG4 MK6 MM5 NA5 NB1 NK3 N0D N33 N65 N90 QYH TR9 TT5 T63 T93 UA1 UL5 U21 U25 U26 U29 U35 VK3 V73 YR1 YT1 YT9 Y06 Z28 1AZ 16P 17C 17I 179 19L 19U 6ZX 7ZX 74A 8NN 9NN.
And the VIN is 1G1AP87H8EN156204.
It is a heavily optioned car, but factory radio delete. see if yall can make any since of what C4B would mean in all of that madness! lol
Old Oct 29, 2016 | 12:25 PM
1987L69's Avatar
Car: 1984 Z28
Re: C4B RPO Code
I double checked my engine suffix code, and its SDR, not C4B
Old Oct 29, 2016 | 12:38 PM
Re: C4B RPO Code
I think it still has to do with your radio delete RPO UL5. Your RPO V73 is for a "fixed mast" antenna. You don't have the RPO U73 for the "fixed mast" fender antenna. I think C4B does two things it deletes your fender antenna when you delete your radio and the fender mast antenna at the same time.
If the original windshield is in the car does it have the wire antenna in it? Do you have an antenna on your fender?
Here is an example of a 1987 GM truck with the RPO U76 which was a windshield antenna and V73 the fixed antenna at the same time.
http://www.pacificp.com/forum/viewto...8cbae173651994
Old Oct 29, 2016 | 12:48 PM
1987L69's Avatar
Car: 1984 Z28
Re: C4B RPO Code
Mine has a manual, retractable antenna on the drivers side rear fender, and does not have an antenna in the windshield, its the factory windshield from what I can tell
Old Oct 29, 2016 | 01:01 PM
Re: C4B RPO Code
I don't think your antenna is stock then because they didn't mount the antennas on the rear in 1984. They were all mounted on the right front fender. So you don't have a hole in the right front fender where an antenna was previously mounted do you? If you don't I would say the C4B has something to do with the fender not having a hole in it and the wiring harness being different so it doesn't have an antenna wire plug in on it.
Old Oct 29, 2016 | 01:06 PM
1987L69's Avatar
Car: 1984 Z28
Re: C4B RPO Code
No hole in the front right fender. I think there is an RPO listed in mine that is for antenna delete, or something of that nature. What are the odds that GM used that code for smaller police departments or highway patrol departments in 1984, just spit balling there
Old Oct 29, 2016 | 01:25 PM
Re: C4B RPO Code
That first link I posted for that 1985 Z28 has the C4B and says it is called a double play value option. Implying it does two things for the price of one. That car also has the U75 for an electric antenna along with the YE2 stereo system. Which reduced the cost of one or the other when ordered together.
It also could have been a credit of some kind for not having an antenna along with the UL5 deleted radio in 1984 which would have saved GM a few bucks since there was no charge for the antenna when a radio was ordered.
