NOS Turn Signal Stalk
Old Jan 30, 2019 | 06:19 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I know it's been discussed a couple of times that the replacement signal stalk has a small shelf under the cruise on/off button. I found this correct NOS piece for a 1987 and older (maybe 88 also) Camaro with cruise and intermittent wipers that does not have the shelf. This stalk looks identical to my car.
https://www.ebay.com/itm/NOS-GM-1984...gAAOSwRsxcO4mz
Old Jan 31, 2019 | 10:41 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: NOS Turn Signal Stalk
Looking at the Firebird side of things here are the different levers.
82-87 - 22510143 (Exclude pulse wiper (CD4) Cruse(K34))
82-89 - 22510732 (Exclude Pulse Wiper & Cruise)
82-87 - 22510144 (W/Pulse wiper (exc Cruise)
82-90 - 22510733 (W/ Pulse Wiper (Exclude Cruise)
82-83 - 25031479 (W Cruise - W/O Pulse Wiper)
84-88 - 25111263 (W/ Cruise W/O Pulse Wiper)
91-92 - 22510733 (Exc Cruise Control K34))
82-83 - 25031478 (W/Pulse Wiper & Cruise)
84-89 - 25111262 (W Pulse, W Cruise)
90-92 - 25111209 (W Cruise)
This is the best I could make of the Parts Catalog.
Old Jan 31, 2019 | 11:12 AM
okfoz's Avatar
Looks pretty good, at least the lettering does, but it is pretty rough for NOS...
Old Jan 31, 2019 | 12:28 PM
scottmoyer's Avatar
Agreed
Old Jan 31, 2019 | 12:33 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Like John said, lettering is mint, but it was a rough 30-ish years in that box.
Old Feb 1, 2019 | 10:32 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
I'm hunting for an 89 switch. GTA, intermittent wipers, cruise, steering wheel controls & VATS.
I think there is a line hunting for this same switch. My stalk still looks good. Both my left and right signal work but right signal won't lock in....left will signal, tough but locks in.
any ideas Okfoz?
Old Feb 2, 2019 | 01:41 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
any ideas Okfoz?
That is a function of the turn signal switch inside the column. Springs can break or pop out. Detent and flat spring can wear.
Old Feb 2, 2019 | 01:48 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
This is correct. Switch is off the shelf part. Unless you have a digital dash in that GTA, in which case it takes a special switch that has a optical sensor that transfers the data for the radio controls on the steering wheel.
Old Feb 2, 2019 | 09:04 PM
Drew's Avatar
When I converted from the aftermarket cruise system in my Iroc over to GM parts, I looked around at cruise control stalks. After about a week or two of watching what they were going for, and scrutinizing ebay pics, I went with the $15 reproduction that mostly looks right. At the end of the day, it's close enough, and it looks the part. Sure an original would be nice, but at a certain point it all comes out in the wash. Price, condition, function, and close on form was good enough.
To be honest, the $$$ cruise stalk I got from the dealer for my Formula is nearly as far off from the original as the $15 repro is from what my Iroc would have had. Diminishing returns.
drknow90rs_ss@y
Apr 21, 2011 12:49 PM
zedder 1 9 9 0
Dec 29, 2001 11:28 AM
