Vin Decode
Old Jul 18, 2020 | 10:05 PM
kenferrell's Avatar
Car: 1985 T/A
Engine: 5.0L
Transmission: Manual
Vin Decode
Can anyone assist in breaking down this Vin?? Both this site and Compnine say its not Valid.
1G2FW87H6FN201758 I have Triple Checked it its correct on the car. I have part of a photocopy of the original Dealer invoice with this number but its mostly unreadable. Id like to be able to know all the RPO for this car.
Old Jul 18, 2020 | 10:15 PM
NoEmissions84TA's Avatar
Re: Vin Decode
https://www.andysautosport.com/learn...vin)_decoding/
Does this site help?
Old Jul 18, 2020 | 10:22 PM
kenferrell's Avatar
Car: 1985 T/A
Engine: 5.0L
Re: Vin Decode
Thanks Andysautosport doesn't help. I have that info was looking for all the RPO codes for it.
Old Jul 18, 2020 | 10:34 PM
JT's Avatar
JT
Community Administrator
Re: Vin Decode
The VIN is valid. Compnine is not saying the VIN is invalid. Just that they don't have records of the VIN in their database. For any 1989 and older ThirdGen that's not an export, that's normal as their records are not complete. Your VIN is a 1985 Trans Am and must not be an export or they would likely have it in their database.
If the above is correct, there is no way to get all the RPO codes associated with the VIN due to its age and lack of records by Pontiac. The best you can do is order a copy of the invoice from PHS. However, it will not contain every single RPO code - only a few of the major items.
Old Jul 19, 2020 | 12:55 AM
kenferrell's Avatar
Car: 1985 T/A
Engine: 5.0L
Re: Vin Decode
Thanks for the info. Car was originally a US car that somehow made its way to Canada.
Old Jul 19, 2020 | 01:26 AM
JT's Avatar
JT
Re: Vin Decode
For clarification, they're all built in the US (Van Nuys, CA or Norwood, OH) with some getting spec'ed for export. Your car was built in Norwood, OH based on the 11th character in the VIN being an N.
Old Jul 19, 2020 | 07:03 PM
kenferrell's Avatar
Car: 1985 T/A
Engine: 5.0L
Re: Vin Decode
Thanks I know they were all built in the US. I meant that this car was originally a Car destined for the US market Sold to a Dealer in Cornelia GA. Speedo and odometer are in Miles. At some point in this cars life it was imported into Canada
Old Jul 24, 2020 | 09:50 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Vin Decode
1G2FW87H6FN201758
1) USA
G) GM
2) Pontiac
F) F-Body
W) Trans Am
87) 2 Door Hatchback?
H) LG4 4BBL
6) Check Digit
F) 1985
N) Norwood
2) Pontiac
01758) One Thousand, seven hundred fifty eighth Firebird off the line in 1985
Best I could do
camarosource
May 29, 2013 02:58 PM
otecnick88GTA
Jan 7, 2008 12:21 AM
pontiacsteve
Feb 4, 2006 04:14 PM
BadBird84
May 11, 2002 07:59 PM
HighHorseZ
Sep 14, 2000 03:28 PM
