VSS
Old Mar 10, 2021 | 11:26 AM
pattydatwo's Avatar
VSS
I own a 1986 Pontiac Firebird Trans Am. It currently has an electric VSS in it that doesn't work and I don't know if it's stock. I wanted to know if these models came with a mechanical or electrical VSS stock. Keep in mind the gauge cluster is all electric and it's an automatic transmission. If it is mechanical, is there a way to convert it and if so how do I go about doing that? If it's not, could someone direct me to a place I can buy this VSS? I have pictures linked below.
Old Mar 10, 2021 | 11:40 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: VSS
https://www.thirdgen.org/forums/tran...ter-cable.html
i May have a used one if needed
Old Mar 10, 2021 | 11:43 AM
Engine: Lb9
Transmission: M20
Re: VSS
Have a sc55 for cable drive and electric that should work or a used one.https://www.thirdgen.org/forums/engi...gears-lot.html
Old Mar 11, 2021 | 11:54 AM
Steve86TA's Avatar
Car: To many to list
Re: VSS
Your 86 is electrical speedometer. That one you have is aftermarket and styled after the 91-92 style
Old Mar 11, 2021 | 12:21 PM
pattydatwo's Avatar
Re: VSS
Any ideas where I can get a one that'll work?
LDR
Jun 25, 2017 03:42 AM
TPI-Formula350-
Mar 24, 2012 09:34 AM
IROCmenace
Apr 22, 2006 11:41 PM
long&low
Jan 7, 2002 05:48 PM
