need rpo codes
Old 10-20-2021, 07:27 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
need rpo codes
I have a 88 formula that the interior and engine, engine harness and ECM were gone when I got it. I hear if I have the vin I may be able to get the rpo's. It's a hardtop with the ws6.
Old 10-20-2021, 07:40 PM
JT
Community Administrator
JT's Avatar
Re: need rpo codes
Unless the car is an export, the only option is to order a copy of the invoice from GM Archive. The invoice will not contain every RPO code.
Go ahead a give us the VIN, here or to me in PM, and I'll check but it's likely not going to be available otherwise.
Old 10-20-2021, 08:24 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: need rpo codes
I will see what happens. What I know it's a 5.7 low option formula. the light blue type. 3.27 posi ws6. Manual windows. I think the interior was gray. There was a few plastic piece in it. Had cruise control. A/c. The wheels on it were the GTA type. If it had 16 in 20 slot formula type. They were gone. Mileage shows 101k. No rust. Very few issues over all
Old 10-20-2021, 08:33 PM
JT
JT's Avatar
Re: need rpo codes
All Formulas came standard with WS6. The "GTA" PW7 wheels was not available on the Formula in 1988. The 5.7 was optional on the Formula and not standard.
Old 10-20-2021, 09:01 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: need rpo codes
Vin number shows it to be a 5.7 unless I got something wrong. 1G2FS2189JL226840
Old 10-20-2021, 09:05 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: need rpo codes
Eighth digit is a 8. I think 5.0 and 2.8 have a letter or different number don't they
Old 10-20-2021, 09:38 PM
JT
JT's Avatar
Re: need rpo codes
Yes. My comment was that the Formula's base engine was not the 5.7. The 5.7 was optional. Therefore, that is an option that was ordered on the car you're inquiring about.
Old 10-26-2021, 01:29 PM
okfoz's Avatar
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: need rpo codes
Yes it is a 350 car.
F = 305 TPI
8 = 350 TPI
E = 305 L03
billbond40
03-19-2010 09:55 AM
tcollinssr
03-09-2005 11:53 AM
SC82TA
05-13-2003 10:40 PM
Quick Reply: need rpo codes
