Do all IROCs have FE2 suspension?
Car: 1989 IROC-Z coupe LB9 T5 G92 N10
Engine: LB9 with L98 cam
Axle/Gears: 9 bolt 3:45 (G92 G80)
Was FE2 suspension standard on all IROCs? Was FE2 available on other Camaros? Z/28s?
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Do all IROCs have FE2 suspension?
Yes.
Only IROCs from '85-'90.
Thanks so based on research on the site, FE2 in 1989 includes:
-36mm (hollow) front stabilizer, 24mm rear stabilizer
-548lbs (BZW) front springs and 131lbs (NNL) rear springs.
-High effort steering box 12:1 (12:7?) ratio 2 1/4 turns lock to lock
-Delco/Bilstein shocks in the rear and special struts up front (some factory variance on this).
-Wonder bar
Did I miss anything as compared to FE1 or F41?
-Wonder bar
Well, Charlie is mostly correct. FE2 was also available on the '91 and '92 Z28s, and B4C cars. Not all later Z28 came with FE2, but it was available to them as an option.
Axle/Gears: BW 3.45
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Axle/Gears: BW 3.45
Did I miss anything on my list of 5 items that come with FE2? I see a few conflicting notes on the steering ratio?
Engine: LT1 6.2L
Axle/Gears: 3.91
