first suspension mod
Old Feb 19, 2004 | 12:21 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
What is the best first suspension mod? Car specs : 5.7 , TPI , Crane 2032 , longtube headers , ported plenum , AFPR , 24# SVO inj. . The tranny is currently being rebuilt with Transgo shift kit, .500 boost valve, vette servo, and vette converter. 3:23 rear end gears. Daily driver with weekend dragstrip duties.
I already have polly tranny mount and end link bushings, but that is all.
Old Feb 19, 2004 | 01:43 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I assume that car came with the 36/24 swaybars?
If so, poly/graphite mount them.
TDS Wonderbar (might have came with stock one)
Then I would say LCA's in the rear, or Panhard bar.
Edit, re-read your post. I would go with LCA's and Panhard.
Old Feb 19, 2004 | 01:46 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Sub-Frames.
end of story. unless you have other issues, in which case, fix your issues first, then subframs
Old Feb 19, 2004 | 01:59 PM
b-man's Avatar
Car: 91 Z28
Engine: 5.7
Transmission: TH-700-R4
Originally posted by Dewey316
Sub-Frames.
Old Feb 19, 2004 | 02:25 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Subframes
Poly sway bar busings and endlinks
Old Feb 19, 2004 | 04:06 PM
Jukka's Avatar
Car: "My American Dream"
Engine: V8
Transmission: auto
I installed Sub-frames, swaybars (34/24) with poly bushings and end links and a wonder bar. The best investment I have done since I bought this car. When i put them on I was like: "dude, is this really the same car, my car?"
Old Feb 19, 2004 | 04:27 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
Another vote for subframes here,unless there is something else that is a saftey issue and needs to be replaced first.
Old Feb 19, 2004 | 09:32 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Ive been told by a bunch of people that the only reason my car has run a best of 14.25(14.4s typically) while being 100% Stock is because of the subframe connectors.
Brace it before you race it...
Old Feb 20, 2004 | 03:27 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Thanks for all of the replies, I will go with the Spohn SFC's since I am putting a Spohn drive shaft loop in when the tranny goes back in. I have read that when the SFC's are welded in it can melt your carpet, is this true? And if it is coud'nt you put ice packs or something on the carpet so it dont melt.
Old Feb 20, 2004 | 03:39 AM
halfpint's Avatar
Shocks, shocks, shocks first! I don't care what else you do, if you don't have GOOD shocks on the car then it will not handle- shocks above SFC's
#2- GOOD tires
#3- Wonderbar, so you don't crack the frame under harder cornering loads
#4- SFC's
Old Feb 20, 2004 | 05:35 AM
MdFormula350's Avatar
subframe connectors which is did first and had all my other stuff already bought to throw on. i didnt melt carpet since its on the very outside of the unibody just weld / spray with and air gun, move over do it again etc..
Old Feb 20, 2004 | 10:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
SFC's.
JamesC
Old Feb 20, 2004 | 11:22 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I agree also with SFC's. If you want a super easy and cheap mod (around 60 bucks) throw a wonderbar on it. I figured since I had SFC's and stuff a wonderbar wouldn't do that much, but it did. You should see a big difference in handling it makes the front end feel a lot tigher.
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
