trim /production tag decode
Old Jan 11, 2024 | 02:21 PM
aussiesteve's Avatar
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
i am in Australia and need this info please
tag on radiator support panel reads AS LAYED OUT ON TAG
C 09C 1FP87L 215052
26C 29L 29U W
AR9 C C1
S 158129
VIN READS
ICIAP87HXCL215052
Old Jan 11, 2024 | 04:44 PM
JT's Avatar
JT
Community Administrator
Re: trim /production tag decode
C 09C 1FP87L 215052
26C 29L 29U W
AR9 C C1
S 158129
VIN READS
ICIAP87HXCL215052
There is not a lot of data to be decoded on the radiator tags.
C - 1982 Model Year
09C - September, 3rd week
29L and 29U - Dark Blue Metallic Upper and Lower (W) Water Based paint
AR9 - Reclining seats
CC1 - T-Top
S - Radio code
Again, the radiator tag does not contain a lot of data to decode. The only options are to find a build sheet, which could be anywhere in the car and may not even be in the car - especially if a RH conversion was done, or order a copy of the invoice from GM.
Lastly, your VIN is wrong. There is no "I".
Old Feb 4, 2024 | 08:43 PM
shiftman's Avatar
Actually, a couple more things.
26C is the interior code. That is Dark Blue Custom Cloth. Total production units are not known.
The H in your 1G1AP87HXCL215052 VIN indicates the RPO LG4 305ci 4-barrel carb engine built by Chevrolet. For the 1982 model year, there were 73,495 LG4 engines in Camaro.
The L in your VIN indicates that your car was built at the Van Nuys, California, assembly plant (Van Nuys is a suburb city of Los Angeles, so the L from Los was used).
Hope this helps.
Best,
Robert
Old Feb 4, 2024 | 08:46 PM
shiftman's Avatar
Oh, I should have mentioned, if you have a Z28, there were 45,569 LG4 in the 1982 Z28.
J. Chris Davis
Apr 6, 2022 08:57 AM
#FiveCamaros!
Oct 16, 2021 04:13 PM
blaze2fury
Dec 29, 2020 05:30 PM
liz-o
Feb 22, 2010 09:51 AM
sweet_87_iroc
Dec 6, 2006 09:42 PM
