1984 Trim Tag
Old Jul 18, 2006 | 09:51 AM
J. Chris Davis's Avatar
1984 Trim Tag
I need to know how to properly read the trim tag on a 1984 Pontiac Trans Am.
Old Jul 18, 2006 | 10:58 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
trim tag???
You mean the 'build sheet' with the 3-digit RPO codes??
Somewhere in the tech articles/FAQ is a list of these codes.
Old Jul 27, 2006 | 09:47 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the body tag
its metal and riveted to the rad core support
post the info codes here, from your tag
Old Jul 28, 2006 | 08:28 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
this might help.
1981 Camaro Trim Tag Information
https://www.thirdgen.org/forums/atta...t-id-plate.jpg
Old Apr 5, 2022 | 06:45 PM
pepsi48's Avatar
Re: 1984 Trim Tag
Does anyone know where the cowl tag is located on an 89 Camaro??
Old Apr 5, 2022 | 07:31 PM
mantaguy's Avatar
Engine: 5.0 EFI
Axle/Gears: 277 Posi Speedo
Re: 1984 Trim Tag
I'm pretty sure 89 didn't have a cowl tag,RPO interior stickers were used.you should make a different thread about the 89 ,you might get more if a response.
Old Apr 6, 2022 | 08:30 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: 1984 Trim Tag
(from member LAFireboyd)
In '86 the new tag was placed in the same location as where the "regular normal everyday body trim tag" was--in that appropriately-designated place on the upper support over the fan area. You can even see that the rivet holes line-up. But after '86 and through '92, the new tag was relocated to near the passenger side of the upper support.
Attached Thumbnails 1984 Trim Tag-124962d1156761527-whats-tag-my
Old Apr 6, 2022 | 08:31 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: 1984 Trim Tag
https://www.thirdgen.org/forums/hist...g-my-core.html
Old Apr 6, 2022 | 08:57 AM
randyhummel's Avatar
Car: 1986 Iroc-z, 1968 Camaro RS-ss
Engine: 305, 396
Transmission: auto
Re: 1984 Trim Tag
In 86 and after only California built cars had the new tag. Ohio Built cars didn't get them.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
Night rider327
Sep 25, 2015 04:19 AM
