4 WHEEL DISCS and POSI
HEY
I HEARD THAT U COULD ONLY GET THE POSI TRACTION IF U HAD THE 4 WHEEL DISC BRAKES....IS THAT TRUE
IF IT IS....I HAVE THE 4 WHEEL DISCS OPTION AND I DONT HAVE THE POSI TRACTION CODE
I HAVE A 1985 IROC Z WITH 305 TPI AND 3.42 GEARS
http://camaroz28.cardomain.com/id.56424
Car: 87 IROC-Z
Transmission: automatic
You have no rpo code G80? The Camaro White Book says rpo j65 required rpo code g80. but then the production numbers are j65 19.871, g80 15,327. You'd think that there would be more G80 than J65.
Go figure
Go figure
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
my rpo code G80 : AXLE POSITRACTION, LIMITED SLIP,so limited slip is positraction?????followed with rpo GU4 : AXLE REAR, 3.08 RATIO,and drum brakes ,should it have a tag on the rear end??
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ive always seen that disc brakes means posi, all of them. and have only seen 3.08 in the disc axles so far(factory) at least in the 80's sw6 t/a's anyways with the ho and 700
Hey
If u look in the 1985 Camaro Sales Brochure u will see that it say that if u have 4 Wheel Discs, Posi is standard....When I went and looked at my RPO codes, I have the 4 Wheel Disc code but not the Posi Traction code...I dont know what is goin on
http://camaroz28.cardomain.com/id/56424
Engine: 4.3L Z TBI
cragg has it right, posi came with the discs, its the same deal with not havin F41 listed on a Z28 car in which i have that deal on my 84 Z28
Engine: 4.3L Z TBI
yeah iw as wondering about that V73 thing ! i just noticed my 84 has power hidden antenna ! so..... lol
about the discs and posi deal, i gues sonly certain years were posi standard with the 4 wheel discs, maybe only on the SW6's like the 85 T/A one was that I cut up for parts last year, was 3.08 and 305 and 700 and such, so.... chevy must be different ?
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
